The screen has a problem I already check the color and contrast just looking for a suggestion
    New Friend:
  • 22 Answers
Video card is going bad. Before long u will just see a blank screen. The only way to fix is pull back off tv and get video card serial number order a new one. About 150$
Posted on Sep 27, 2014
Samsung contrast problem
Faulty T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 10, 2016 | Samsung Televison & Video
Too dark
well...the contrast comes to mind first, and then the color temperature..it's all accessible from the menu, of course.
I'd start with contrast, and then look at the color temperature ratings..
Apr 27, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
The color is too dark how do i feel the color i already put the color contrast and brightness to the maximum which is 100 but its still not bright enough what else can i do. do i need a new monitor
open the monitor you will see the eht a biggest black part on pcb take the screwdriver and rotate the preset on that eht on which screen is written .do it in active monitor and look on the screen and finish after satisfaction
Mar 04, 2010 | E-Machines eMachines Monitor E15T4
I want to change the led color on my blackberry
You cannot make any changes in LED colour settings.However, you can set the color contrast of application interfaces, menus, and pop-up screens to Normal, Grayscale, or Reverse Contrast. To change the color contrast, complete the following steps:
  1. In the Options application, click Screen/Keyboard.
  2. Set the Color Contrast field to Normal, Reverse Contrast, or Grayscale.
  3. Press the Menu key.
  4. Click Save.
Oct 29, 2009 | RIM BlackBerry Pearl 8100
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Flash File Overall Color and Contrast too light
MAINLY CONTRAST OF THE FILE IS DUE 2 BRIGHT COLORS. SO YOU BETTEER 2 USE LIGHT CLORS. & BRIGHTNESS MUST BEE REDUCED 2 SOME WAT ACCORIND 2 YOUR PROJECT
Sep 26, 2007 | Macromedia Flash MX
Strange picture issues
check near lineoutput transformer low value resistor eiher open circuit or high needs technician
Mar 18, 2007 | Samsung DynaFlat TX-P3064W 30" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
