Our tv will not turn on! We have tried everything. Everything else works but the tv itself, is there a reset button or something we can try?
  • jennifer ricks Dec 01, 2012
    Model # DP42841...I have a question, is the power supply something that is easy to c hange? Can I change this myself or do I have to bring it to someone to fix?
My Toshiba tv goes to max volume every couple of minuets by itself
Do you have something new in the room that emitts IR signals?
You need to isolate the TV from a possibly rogue IR signal.
Try turning everything off in the room, unplug everything except the TV and Cable box if you are using one.
Turn off all the lights and turn the TV on and select a channel.
Is everything working, is the volume OK?
If you are still experiencing volume issues then this is TV problem and you will need to see a service centre or repair shop.
But if the sound is OK, then you can now start turning things on one at a time to see which device is causing your issue.
It could even be a light that is flickering at just the right frequency to cause your issue.
If it is a CFC or LED light, try a different manufacturer
Nov 04, 2017 | Toshiba Televison & Video
I have a 32" LCD
Tries tv and cable box unplug,replug it back like about an hour later.For the tv to do a resetting itself back to the factory setting.The cable box to reboot and upgraded it software.Than go in to the tv Menu go to Audio Setting go down and do a resetting back to the tv factory setting.By doing these steps u have a great chances to get ur tv audio sound back.Not have the same problems after this than the tv Tuner signal board it is shorted in the audio ICS modjulation sections.Tries websites like Shopjimmy,com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 16, 2011 | Televison & Video
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
I have a 50 inch LG plasma tv that is less than 2 years old. It use to turn on by itself throughout the night, and now it's completely not working???
Hi there
Try doing a system reset on the TV, by unplugging everything from it, then wait 3 minutes and plug the power lead in only. If it works, then plug everything back in one by one. If the problem persists it may be that the software has been corrupted in an update process, which can be performed at night via the aerial signal (this may be why it was turning on at night). In which case contact the TV manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | LG 50PX4D 50 in. Plasma Television
I replaced my lamp bulb and everything works fine. The only problem is that the orange, replace indicator, is still on. Is there a way to reset it or something? TV and everything works great just the...
Try tv unplug,replug it back like an hour later.The tv will reset itself,back to the factory setting.It should detect the projection Lamp life are good and a new Lamp.The "LAMP" LED Light indicator,will go off.
Nov 30, 2010 | Zenith E44W46LCD 44" Rear Projection...
Hey, i bought a DLP Toshiba HDTV off a guy on graigslist, when i went to go pick it up he turned it on by remote and everything worked fine as it should. When i got back to my place I tried turning it on...
These DLP tvs sometime u unplug suddenly and replug it back wright away,tv will go into protective mode and will not work wright away.Tries tv unplug,replug it back about an hour later,now the tv will reset itself back to the factory setting.The tv should work now.
Nov 17, 2010 | Toshiba 65H93 65" Rear Projection...
My ps3 hdmi is not working. The ps3 plays on av settings but when i go to switch the display settings to hdmi nothing happens. I've tried everything holding the button down for 5 seconds until it beeps to...
Make sure you're running the latest firmware version. 2.76 right now.
If you are and you still have the problem then it's probably an issue with the PS3 itself.
Easiest way to confirm is taking your unit to a friends house and using his tv and his cables.
Hope this helps.
Jun 18, 2009 | Video Game Consoles & Games
All buttons on tv stopped working only turns ON no ...
There is a button lock in the menu of the television. Using your remote access the menu screen and unlock the buttons.
Feb 19, 2009 | ViewSonic N3735W 37 in. LCD TV
Control buttons don't work!?
Same problem. While waiting for feedback from their support, after trying everything I could think of with no result, in frustration I just shut it down and turned off the power to everything since I couldn't turn the monitor off. Left it overnight and this morning when I rebooted it now works so it must reset itself. Good luck
Jan 01, 2009 | Westinghouse 19" Widescreen Flat Panel LCD...
Tv was working fine...then shut itself off.
there is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Nov 21, 2006 | RCA F27242GY 27" TV
Televison & Video Logo
Top Televison & Video Experts
