Question about Optics
I have an old (1992) Celestron 8" SC. Haven't used it in many years. The surface of the eyepieces (30 mm, 12 mm, and 9mm) look like they have small spider web markings. Is this something I should be concerned about?
  • wmichne Jan 11, 2009
    As suggested, I cleaned the eyepieces using lens cleaner and lens tissues. Problem solved! Thanks!
  • 3,186 Answers
The eyepieces are dirty-- try cleaning them. They should be "clear" glass with a blue or slightly green coating. Some eyepieces are perfectly clear and not coated. But none have spider webs on them!
http://www.cloudynights.com/item.php?item_id=510
How to clean eyepieces--
Posted on Jan 11, 2009
Which lens is more powerful..a 10mm or a 20mm?
A 10 mm. If you know the focal length of your scope, divide that by the focal length of the eyepiece, and the answer is the magnification you will get. However bear in mind when viewing astro objects, a very high magnification will degrade the image sharpness, and make the object hard to get on centre. Most experienced amateur astronomers use a medium power eyepiece at most.
Mar 08, 2014 | Celestron AstroMaster 114 AZ (50 x 114mm)...
Meade model 6600 need eye pieces
This telescope has a 1.25" eyepiece holder. This is standard, many brands are available. If you are just getting started a few eyepieces are all you need. I recommend Plossl or Super Plossl at approximately 32 mm, 12.5 mm, and something from 6-9 mm, but this really depends on what you are looking at most often. Add one Barlow and you have the equivalent of 6 eyepieces.
When I was getting started, I bought a simple kit from Zhumell (Lunar and Planetary) which came with barlow, moon filter and several other filters. These are better than the cheap plastic ones that come with low end telescopes, but still very affordable and reasonable quality for beginner/intermediate users. Celestron, Meade, and others have similar kits, and smaller ones if you are on a budget. Used lenses can be found on Astromart classifieds and Cloudy NIghts or other astronomy forums.
More importantly, I bought a good book (Star Watch by Harrison) and spent some time learning how to find things. A telrad (unit-finder) was very helpful too.
Jun 02, 2011 | Optics
I TOOK THE EYEPIECE APART TO CLEAN IT AND HAVE THE LENSES OUT OF ORDER, WHAT IS THE CONFIGURATION OF THESE LENSES? CELESTRON 114.
NEVER EVER disassemble an eyepiece --- no one can tell you how the lenses go together there are dozens of combinations and some eyepieces have as many as 6-8 glass lenses inside!
Sorry buy another eyepiece and only clean the outside surfaces.
Jan 07, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
I have the Nexstar 8. It will not auto align or manual....
First do a RESET on the hand controller and make sure TIME, DATE, and SITE, are correct.
If this does not work then RE-load the firmware in the hand controller. If that fails contact Celestron customer service.
http://www.celestron.com/c3/page.php?PageID=37
May 15, 2010 | Celestron NexStar 102 SLT 102 mm (4.0)...
Need eyepiece etc - don't know what to buy or where to find it
Here is your scope:
http://www.celestron.com/c3/product.php?ProdID=391
It's discontinued: however call Celestron and see if they still have parts?
Good luck.
Sep 12, 2009 | Celestron Optics
Not seeing
The city lights will not hamper planetary viewing. Excessive power is a common mis-conception. Use 80x or so for best viewing. That would be about a 4mm eyepiece. Start with lower powers and work upwards in easy steps. The greater the power, the narrower the field of view, and it becomes very hard to find anything at all.
Apr 18, 2009 | Celestron NexStar 130 SLT (306 x 130mm)...
Acquired a used Parks Astronomical Telescope 60 mm - 700 mm. w/90degree eyepiece is a G.S-7 5mm. My 9yr old grandson (a future engineer) decided he wanted to know how it was put together and while I...
Just found your posting kind of old but I hope this helps you--
Most of these small refractors assemble the same way-- so take a look at these Meade brand refractor manual and see if it helps you put it back together.
http://www.meade.com/manuals/TelescopeManuals/Refractors/90AZ-ADR.pdf
http://www.meade.com/manuals/TelescopeManuals/Refractors/Meade-RB60.pdf
Feb 18, 2009 | Celestron PowerSeeker 60 Astronomical...
How use a telescope celestron 21041
The power seeker 60's are hard to use a high power due to the 60mm objective. try starting out with a 25mm eyepiece on the moon or some think bright and work from there.
Dec 03, 2008 | Celestron PowerSeeker 60 Astronomical...
Optics Logo
74 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
