Question about Brother Sewing Machines
Brother LS-2000 machine with the up thread not keeping a good tension. Is it possible to remove the plastic cover on the up thread spring to check for lint ?
I have experience cleaning an up thread spring in an old machine because it is easy to just unscrew the front part however I am wondering how I get the plastic cover off in the new machines to get at the spring without breaking something. The tension is all crazy where the up thread does not seem to be engaged properly even though I can see that the spring in not broken. (It is a very new machine.) Thank you.
  • Brother Master
  • 1,564 Answers
I have a newer brother too. I suspect the case is put together much like a laptop or game console is these days. But before I would go that far... maybe try "flossing" it with a piece of light canvas or denim folded double. ;)
Posted on Nov 30, 2012
SOURCE: brother CS-6000i
I have the same problem but I believe the answer is to purchase a new shuttle which is the part the bobbin sits in and is most likely scratched or damaged. The quote I got was 40-50 dollars
Posted on Nov 18, 2007
Paul319581
  • 101 Answers
SOURCE: my grandmas's New Home (Janome now) 531 machine
i don't know much about this
but try changing the thread !
Posted on Mar 09, 2008
SOURCE: Brother XL-5340 sewing machine
I have the same problem! except mine doesn't break thread, it just comes out. Oh, mine's a ELNA Transforma
Posted on Nov 16, 2008
  • 55 Answers
SOURCE: Thread Breaking On Brother Sewing Machine
if thread is good quality you may have a sharp groove in your needle plate hole from needle breakage. if so, polish with emery tape.
scott
Posted on Jul 27, 2009
  • 3 Answers
SOURCE: MY BROTHER MACHINE NO. LS-2125i THREAD BREAKING WHEN SEWING?
Thread brekage can be caused by several things but start simple by taking off the needle plate then thoroughly clean the sewing mechanism and add a few drops of oil, then check the threading is correct. replace the needle. Always use quality threads and make sure that the thread is not to heavy for the size of the needle (it should pass easily through the needles eye). check that the needle hole in the plate is not bent or damaged and peppered with needle marks, a damaged plate will cause many problems. Finally, make sure that the tensions are not too tight this can be a major cause of thread breakage especially if poor quality thread is used. ( check thread by breaking it by hand, it should offer good resistance to breakage, if it breaks easily then discard it. hope this is useful, best of luck.
Posted on Apr 14, 2010
How do I remove plastic cover on brother innovis v3 to see if thread tension discs are clogged. There doesn't appear to be a screw to undo.
You should NOT disassemble the tension disk unless you want an expensive repair bill. Instead, raise the presser foot and set the tension to the highest number possible. Then you can gently slide a piece of fabric, pearl cotton, or UNWAXED dental floss DOWN through the tension disk to dislodge any lint/dirt or any pieces of thread.
Nov 15, 2016 | Brother Sewing Machines
Free motion quilting bobbin thread come to the top
check the timing between the needle and rotating hook also check the teeth for possible lost of timing maybe low or high to much.
Nov 06, 2013 | Brother CS6000i Computerized Sewing...
How can I adjust the timing on a brother ls 1217 sewing machine
Unfortunately, it's not recommended for users to repair their own brother machines. It sounds like the timing is out anyway... to take it in and have it "Cleaned, Lubed, timed and the Tension repaired"
Or you could use it for target practice and just go buy another machine.
Dec 12, 2012 | Brother LS-1217 Mechanical Sewing Machine
I am experiencing tension issues. Same fabric and thread, worked with the first spooling of the bobbin. Re-spooled the bobbin and now the tension is all messed up. Cannot tighten, and it's gathering...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Brother CS-6000
Upper thread keeps breaking
the tension is too tight give it a little slack on the top.good luck.
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
May 27, 2009 | Brother LS-2125 Mechanical Sewing Machine
My thread tension knob fell out of my machine and I can't get it to stay back in Model brother LS-1217
Open the end where the light is, look for a set screw at the point where the tension assemly enters machine. try tightening that. If that doesnt work, post a reply comment and I will tell you where to go next.
Mar 21, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin holder keeps catchin thread
Try re-threading, make sure the presser lifer is up so the tension discs are open and the thread will go into them. It sounds like you may have missed either the upper tension discs or the take up lever.
A drop of oil on the hook wouldn't hurt if you haven't oiled in awhile.
good luck!
Jan 28, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother vx-950 sewing machine
Place thread spool on the spool pin at back right top of machine. From there, thread through 1) rear thread guide (little hook), 2) front thread guide (front hook), 3) down and up through the thread tension dial from right to left so that thread picks up the thread spring check (the little spring on the left of the tension dial). 4) Through the thread take-up-lever, from right to left (the little lever that goes up and down). 5) Through the thread guard and guides (one on the front, one on the needle arm). 6) Through the needle, front to back. Good luck johntrev800 (at) yahoo.com
Oct 21, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
152 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
