I just purchased the Linksys Wireless-G Broadband Router. I tried to install it on my computer...got to step 4 with the setup from the cd included with the routher, but an error message comes up that says the internet can not be accessed and to check the configuration of all my cables. The cables are in the correct spots (according to the set-up cd, but it still won't work. My internet provider is windstream and I am working with their modem. Any suggestions???
Thank you.
Comments:
Jan 11, 2009
- Yes, I had the ethernet from my modem box to the router and the included blue ethernet from the router to my laptop. I just got the Linksys router and no, I haven't ever been able to get it to work. If I leave the router out of the equation and just hook up to the windstream modem (SpeedStream 4200), then I can access the internet with no problem, but when I include the router and go through the disk set-up and get to step 4 (pluging the router power cord in) and hit next, it searches for the internet connection, but is not able to connect.
Is the ethernet from your modem box going to the router?
Same Problem
Jan 29, 2009
-   I have the same problem. I contacted my ISP and they ran the diagnostics on my modem and on my router. They had me reset the router which I did, and then the ISP informed me that the ISP was communicating with my modem, my router and my computer. But, when I try to set up the network, I'm told the router can't find the internet .... which is really odd ... since I can access the internet (although it's slower than I'd like, but still a reasonable speed) and the ISP server seems to be able to talk to it via the cable modem. The router is a combination wireless and wire router -- I have my printer using one of the physical connections. Currently there is no other computer networked (except for my main computer) on my 'network.' Any suggestions? My router is a LInksys WRT54G broadband router with 4 port switch.-   thegrislybar
Jan 20, 2009
-   I'm having the same problem :( I have used my router before when I lived at a different location. But now, I hooked my Verizon box to my Linsys, got everything hooked up (correctly) and then it tells me the internet cannot be accessed. Someone help!
-   mabfaery
You must connect a network cable ( cat5 - not a cord ) from your PC to the router at that point of the set-up making sure you connect it to the right router port.
Comments:
Jan 26, 2009
- Make sure that all link lights are on first and that cable or telephone line are securely connected
Hi, i have an actiontec GT704-WG router, and my laptop connects to it through wireless. i've been...
(More)
Hi, i have an actiontec GT704-WG router, and my laptop connects to it through wireless. i've been using Emule but its extremely slow, so i figure i've got a low ID. Then I've turned on the UPNP, and changed the firewall setting. But i still cant pass the port test. so how can i get a highID? Thank you !!!!
