Armstrong Hanging Gas Heater won't fire up - Heating & Cooling
2 Suggested Answers
  • 1015 Answers
SOURCE: Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
Posted on May 19, 2011
Testimonial: "Hi frodo,Thanks for the quick response i will try the advice you mentioned. I will let you know if this works.Thanks again. olmate 56"
I have Armstrong hanging heater that I would like to install in my garage. I have 3" Type B pipe but the connection from the heater is only a 2" can I just slide the 3" over the 2" and call it good?
No. You need an adapter. Otherwise exhaust from the heater could build up in the gatage. Carbon monoxide is a colorless odorless gas that can kill you.
Oct 13, 2016 | Armstrong Cars & Trucks
Heater fires up but won't keep heating water
Sounds like the sensor is not working shutting down too early
Jan 06, 2018 | RTO Atwood Water Heater - 6 Gal LP
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
Won't start can't even get it to fire got spark getting gas ,don't know.
Check the compression! It has to be around 120 and no less then 100 to fire off. If it is ok, Have your carb checked out. It should fire off with some spray.
Feb 10, 2013 | Poulan Garden
Laars lx won't ignite
hot surface igniter may not be hot enough to ignite the burners
Jan 09, 2013 | Teledyne Laars Laars Lx Pool Heater /...
Williams gas wall unit won't burn.
It's a burner control problem. It maybe a defect on some protective devices (pressure switch, fire detector, etc.), a blown fuse, or a board defect (busted DC supply transformer, relays, or electronic devices).
Nov 12, 2012 | Heating & Cooling
Waterheater does not ingnite.
Usually when a water heater won't ignite it is a bad thermal coupler. It is anywhere from about $10-29 part depending on your model. I do recommend that with anything natural gas or LPG fired you seek help from a certified technician. If you should cause an undetected gas leak it could result in fire and or death. Please be very careful with all mechanical repairs and hire a professional if you are the least bit uncertain or it is above your mechanical ability.
Aug 19, 2011 | Dryers
Gvc code heater won't fire
gas valve closed check gas pressure
May 28, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
May 19, 2011 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
