Question about Keurig B70 Coffee Maker
New unit wont prime
Why wont it prime
  • dmcg221 Jan 10, 2009
    bRING IT BACK TO VENDOR ITS NOT WORTH MESSING WITH
  • hubbabin Feb 28, 2009
    Try pinching the vent tube in the tank while it's trying to brew - but not while it's refilling.
I just got my b70 and had the same problem. i called customer service and they walked me through the steps of resetting the unit and then getting it to prime. Worked perfectly after that. call them, they were super friendly and helpful, if all else fails they will replace your unit with a new one, since there is a warranty.
Posted on Mar 20, 2009
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
Primer wont prime
put a new primer bulb on it if the old one is cracked it wont prime.
May 02, 2016 | Garden
Lighting instructions for oil furnace
Air in line. Prime and shut off power to unit at least 1 minute
Apr 24, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Blower does not get any fuel. Installed new carb checked and removed fuel filter and air vent and still wont start. why is it not getting any fuel? what have I missed?
One question: Is the unit equipped with a primer? If so what does priming do? If it wont prime do the following:
Check your fuel lines to verify they arent collapsed or blocked. Also replace the fuel clunk in the gas tank. Check fuel cap vent for blockage too. Finally, make sure the fuel lines havent been crossed. Good luck and be careful!
Oct 01, 2013 | Echo Gas Blower 135 MPH390 CFM Blower...
My spraytech 1620 wont stay primed,and it's not the ball..what do i need to do or buy for it ????
It was probably from Home Depot,was it a refurbished unit as Home Depot will just do a basic flush and lube the fittings/seals..try getting a repack kit from them.
Oct 19, 2012 | 1620
If oil pressure sending unit is bad will it stop fuel pump from working on a 2000 blazer
You should never try a pump without it being in fuel. It uses fuel for lubrication when it is running. If the vehicle doesn't start at all when you first crank it over it is not the oil pressure sender. If you just put the pump in you might want to turn the key off and on several times to cycle the pump then try to start it. If it doesn't start then check fuel filter or check fuel pressure at fuel rail in engine compartment. Is fuel pump cycling at all when the key is turned on? There is a problem with ignition switches on some of these blazers.
Jan 04, 2012 | Chevrolet Cars & Trucks
WE OWN 92 CAMARO RS 25TH EDITION IT WONT START ITS GOT FIRE POWER AND SPARK SO NOW WHAT ITS DRIVE ME CRAZY WHAT TO DO. WE CHECK THE SPARK PLUG AND BATTERY AND ITS GOT GAS BUT IT WONT START WHAT DO U THINK...
92 Camaro, V8 5.7 multi port, new pump, good preasure. runs when primed, wont start without prime. After sitting a few minutes, engine fires wont start. How to check EGR Valve and what does it do?
Feb 15, 2011 | 1992 Chevrolet Camaro
ZXR750H2 1991 FUEL PUMP WONT PRIME
jump the pump run a hotlead to pump
Jul 05, 2010 | 1990 kawasaki ZXR 750
Keurig B70 Coffee Maker Logo
744 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
