Usb ports not working
I just received my new pc today and at the back it has 4 usb ports , 2 black and 2 blue but the blue ones don't do anything , could they be faulty and why would they be different colours ?
  • 27,725 Answers
What brand and type of computer
IE asus Desktop Laptop ?.....
You should look at the user manual that came with the computer or contact the supplier/seller for more information
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Hope it helps.
Posted on Nov 29, 2012
3 Suggested Answers
BENTECH7
  • 132 Answers
SOURCE: My drive has been working
Try to scan your Had Drive with updated anti virus it may attacked by a virus. Connect it again where the hard drive is working fine. I have some clarification if you disconnect it properly in the computer where you have the time you use it. Because if you disconnect it in your PC without proper procedure it may possible cause of corrupting you files inside you hard drive or internal damage to your hard drive.
Posted on Jul 19, 2011
  • 451 Answers
SOURCE: My hard drive don't work in the USB port on my toshiba 26el800a tv
this toshiba tv only supports harddrives that are formatted in FAT32 format.
you will need to reformat your hard drive to FAT32 in order to display pictures and play audio.
there is no other support for movies etc according to toshiba's websitehttp://www.mytoshiba.com.au/products/televisions/led-backlit-tv/el800a/26el800a/specifications#details
Posted on Feb 28, 2012
TEAC TK8060 and mouse don't work together
make sure that the mouse and keyboard are plugged into the usb ports in the front or in the back. if wireless i think one is interfering with the other signal
Feb 17, 2012 | Audio Players & Recorders
Hi my wireless keyboard & mouse do not work at all on my Acer Aspire M3970, but both a cable keyboard & mouse do?
There is a USB receiver underneath the battery panel of the mouse, although it looks like part of the workings of the mouse. It's only a very small thing with a USB plug on it but it is there. The instructions don't show a picture of it, so it's very easy to think you haven't got one until you look closely
Unclip it and put it in your USB port and it should come up.
Nov 10, 2011 | Computers & Internet
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
Sep 12, 2011 | Dell Computers & Internet
I just got the mp3 player. ive been charging it but when i disconnect it from my computer it shuts off and wont turn back on. HELP!
Some older computers that have USB ports that limit the output to 5V @ .5 amp current. Depending on your MP3 player, it may not be sufficient to charge the player. This was the spec back then. Since then, new USB specs call for 5V @ 1.0 amp current - a two fold increase in current.
You may have better luck connecting to a powered USB hub instead. If you're only looking to charge the MP3 player, you don't even need to connect it to the computer. The powered hub gets powered by connecting the ac adapter / power supply to a wall outlet - instead from of the computer's power supply via mother board.
The above assumes there is a good, rechargeable battery; a functioning charger & USB port in the MP3 player and of course, a working USB cable. If any of the above is faulty, you'll never get the MP3 Player to accept a charge. You should try different computers, cables and ports if possible.
Sep 07, 2011 | Computers & Internet
My acer Aspire 57342 usb port seems broke. How do I get it fixed. I have an air card in the rear port but the front port I can't plug my mouse or printer into. Also another question are both usb...
BAD News.
Usually the USB Port is a part of the Mother Board on a PC and the replacement of the Mother Board is the only solution.
You can find them on the internet at Ebay and other locations. BUT it is very involved to replace.
If you have one good USB Port, Get an adapter that will allow multiple inputs.
Example:
http://www.staples.com/Staples-4-Port-USB-2.0-Hub/product_837531
http://www.amazon.com/Belkin-4-Port-Ultra-Mini-F5U407/dp/B000Q8UAWY/ref=sr_1_1?s=electronics&ie=UTF8&qid=1311466822&sr=1-1
http://cgi.ebay.com/High-Speed-USB-2-0-4-Port-Hub-Splitter-Cable-Adapter-/280673924100?pt=LH_DefaultDomain_0&hash=item4159783404
Question 2. I do not know. On most PC's two are horizintal and two are vertical.
Jul 23, 2011 | Acer Computers & Internet
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Pc won't recognise scanner after installation I am looking for a free windows 7 driver update. problem is I have 2 usb ports close together and don't have a usb hub...any suggestions
ok, you purchase a 4 /8 port USB first. This is a adiitional device which is insatll through USB port. after that you can get additional 4/8 USB port.
Thanks.
May 13, 2011 | Computers & Internet
Its showing just blue background on the screen wita mesage NO SIGNAL.
If you are trying to capture from a digital camcorder (tape), you have to use a firewire connection, USB does not work as stated in requirements.
Adding to what Walt said, firewire cables don't connect to a USB port. If you don't have a firewire cable, you need to purchase one. And if you do, don't buy a cheap one. Buy cheap, buy twice.
May 06, 2011 | Cameras
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
