Question about Canon imagePROGRAF iPF8000 Printer
Ipf8300 canon 03130031-2f48
Have this error how do clear this also does not detect paper size issue
SOURCE: Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
Posted on Apr 01, 2008
SOURCE: I have a Canon Pixma
It was covered by Staples Extended warrantee and they exchanged it.
Posted on Nov 15, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
  • 92 Answers
SOURCE: canon image class mf5750 legal size paper
Hi ...
If you wish to print using a paper size which is different from the normal one A4, you need to specify the same to the printer else it will not recognize or will not accept the paper ...
Below are the steps that you can follow to:
1) Specify paper size
2) Specify paper type ..
Specifying the Paper Size At the factory, the paper size has already been set to [LTR]. Normally, you can make copies in this setting. When making copies on other sizes of paper, you need to specify the paper size according to the following.
  1. Press <Menu>.
  2. Press <la.gif> or <ra.gif> to select [COMMON SETTINGS], then press <Set>.
  3. Press <la.gif> or <ra.gif> to select [PAPER SETTINGS], then press <Set>.
  4. Press <la.gif> or <ra.gif> to select [PAPER SIZE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper size (LTR, LGL, EXECUTIV, A4, B5, ENVELOPE, or FREE SIZE), then press <Set>.
    black_dot.gif When [ENVELOPE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select the type of envelopes (COM10, MONARCH, DL, or ISO-C5), then press <Set>.
    black_dot.gif When [FREE SIZE] is selected: white_square.gif Press <la.gif> or <ra.gif> to select [VERTICAL SIZE] or [HORIZONTAL SIZE], then press <Set>. white_square.gif Use the numeric keys, or press <la.gif> or <ra.gif> to specify vertical and horizontal sizes of the paper in millimeters (mm).
    Available range in [VERTICAL SIZE]: 127 mm to 356 mm (5" to 14")
    Available range in [HORIZONTAL SIZE]: 76 mm to 216 mm (3" to 8 1/2") white_square.gif Press <Set>. Repeat the steps above to specify both vertical and horizontal sizes of the paper.
  6. Press <Stop/Reset> to return to the standby display.
Specifying the Paper Type [PLAIN PAPER] is selected as the default paper type. When making copies on paper other than plain paper, you can specify the paper type according to the following. Specifying the paper type can prevent poor copy quality, or the printout not being printed correctly.
  1. Press <Menu>.
  4. Press <la.gif> or <ra.gif> to select [PAPER TYPE], then press <Set>.
  5. Press <la.gif> or <ra.gif> to select the appropriate paper type, then press <Set>.
    You can select from the following paper types: - Plain paper (17 lb to 24 lb (64 g/m2 to 90 g/m2 )): [PLAIN PAPER] - Heavy paper (25 lb to 34 lb (91 g/m2 to 128 g/m2 )): [HEAVY PAPER], [HEAVY PAPER H]*1 - Transparency: [TRANSPARENCY] - Label*2 : [HEAVY PAPER], [HEAVY PAPER H]*1 - Envelope: [HEAVY PAPER], [HEAVY PAPER H]*1*1 If print fixing is not sufficient when printed with [HEAVY PAPER] selected, select [HEAVY PAPER H].
    *2 A label that can be loaded in the cassette is a standard type (label standard card) only.
Please vote if this helps ... Cheers :)
Posted on Jul 27, 2009
SOURCE: Canon MF5700 Printer Error - It says change paper
press the menu then # key the m/c shows sssw then ok key, press the left or right key upto the display shows clear then ok key,press left or right key upto yhe display shows all then ok key,the wait the m/c reset itself switch the m/c off then on
Posted on Sep 11, 2009
Canon iPF 8300: Hardware Error 2F48
Canon have a Technical Bulletin regarding this error (TP11 3337d.pdf). In my experience it starts with E161-403F/E and if you get past this in Service Mode it cannot detect the paper size (the multi-sensor lights on the carriage do not work). After re-seating the flex into the PCB I got the 2F48 error. I think it is related to poor ink flow at some point.
The bulletin recommends (after updating firmware) you:
-Turn printer off
-Remove both heads and dispose of them (Can carriage EEPROM corrupt new heads? $1000 in the bin?) - bulletin states heads MUST NOT BE REUSED so seems like they mean it.
- Replace Carriage PCB - another cost!
- Turn on in Service Mode - WITHOUT HEADS INSTALLED YET
- Turn off (clears errors)
- Turn on in User Mode and install heads as normal
- Check ink is flowing into heads - if not you may well fry another head so you need to get hold of a Syringe Kit to pull it through manually (don't ask me how!)
The bulletin also then - disgracefully I add - goes on to say that if this doesn't work change the Main PCB as if the $2000 outlay to do so was an arbitrary amount of money to pay to get the clearly mal-designed printer to work again!
Good luck anyone reading this, I'm about to do this myself today on my Canon iPF8300S - but before I hook out the Carriage Relay PCB and heads I'm going to connect a new flex from Main PCB to Carriage PCB and hold it in the air while the printer initializes (chasing it through the machine is a ballache if not required). The crushing of the flex by the chain/against plastic mount is far too common - and a known issue since ipf8000 at least and definitely worth a try if more than one head error occurs.
Aug 30, 2013 | Canon Office Equipment & Supplies
Paper size not detected on Canon IPF8300
message of "Paper size not detected" in the printer Canon iPF8300S
kindly help me
Jan 18, 2013 | HP Photosmart 3210 Printer
Close carriage cover ipf8300
I have tried to find this elusive black flap you are refering to ... are you sure we are talking about the Canon 1pf8300 44" printer?
Aug 13, 2012 | Canon imagePROGRAF iPF8000 Printer
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Software problem with canon copier ir5000i
Why don't you change the third paper tray to the size you need. It is the only paper tray that can be change by a end user. The second question is the smallest paper size is a Statement Size, about 5x8, and it will not do envelopes at all the paper path is to long between the paper feed rollers. Good Luck
Jan 05, 2009 | Canon imageRUNNER 5000 Copier
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Jun 01, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
PAPER SIZE DETECTION ERROR
Are you tring to use a paper tray or the manual by pass tray?If you are tring to use a paper tray for more then one or more copiers, you are going to have to ask your service techs to change the setting of one of your paper trays to A4 in service mode. Or if that has been done, look behind the paper trays for a wade of paper blocking the size detect switchs behind the paper trays. Good Luck
Mar 03, 2008 | Canon CLC 1120 Color Copier
Paper sizing error
Jun 29, 2007 | Canon imageCLASS MF5750 All-In-One Laser...
Canon imagePROGRAF  iPF8000 Printer Logo
637 people viewed this question
old marine
old marine
