Harman Kardon AVR 142 has no sound when i 1st switch it on, sometimes letting off a high pitch tone ,but if i switch it off and then back on the sound resumes as normal... on input Video 1/Analogue
All other devices that are required to play the sound are switched on at the time.
    Sergeant:
  • 344 Answers
You have a serious problem ewsith it that only a trained tech will have to figure out, Good luck, I would just get a different one, IT will cost you less, Then to have it repaired, I use to be a tech, Untill i retired this summer after doing it for 45 years,
Posted on Nov 29, 2012
  • darkyungthan
    darkyungthan Nov 29, 2012
    Thanks Lissa, i called up Harman Kardon and their technical advisor couldn't do much but give me a number to a local rapair shop;-(
cheebster
  • 39 Answers
SOURCE: harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
Posted on Jul 10, 2007
SOURCE: Harman Kardon AVR 120 turns off by itself after normal work for about 1 min
Followup on higlider's problem. Now it has to be turned on ten times before it stays on. Email from Harman Kardon only suggests taking it to an authorized repair shop. It is clear that it is not from speaker short or overheating, because it only happens when the rcvr is cold.
-higlider
Posted on Jan 05, 2008
SOURCE: Harman Kardon AVR 40 no sound
Check the fuses - there may be one inside the box as well. May also be a bad transformer. You can get a multi-meter at Home Depot and lookup how to check the power at the transformer.
Posted on Sep 06, 2008
  • 382 Answers
SOURCE: can I conect harman Kardon avr 230 to apple tv
Yes, although it (AVR) does not support HDMI only component video.
Connect the audio to the receiver and the video directly to the TV if you have inadequate video inputs, or want to take advantage of the HDMI.
Posted on Jan 01, 2010
Testimonial: "cheers, have a good year."
SOURCE: Harman/kardon avr 247 no audio or LED display on the reciever
I've had the exact problem. HK in the states is no help, you need to deal with a company in Montreal (Jan Industries). Regular techs are unable to fix it without schematics that only authorized dealers have and the manufacturer. This problem happened to me just after 2 years and outside warranty. I've bought a Yamaha today.
Posted on Apr 03, 2010
HOW TO RESET HARMAN KARDON AVR70
Hi, Try this. Hope this helps and I have the link here to the manual.
Processor Reset
If the AVr behaves erratically after a power surge, first turn off the front-panel
main
power switch and unplug the Ac power cord for at least 3 minutes. plug the cord back
in and turn the AVr on. If this procedure doesn't help, reset the AVr's processor as
described below.
note: resetting the processor will erase all user configurations, including speaker and
level settings, and tuner presets. After a reset, reenter all of these settings from your
notes in the Appendix worksheets.
To reset the AVR's processor:
1. press the front-panel Standby/on switch to place the unit in the Standby mode (the
Standby Indicator led will turn amber).
2. press and hold the front-panel Standby and memory/folder buttons until the reSet
message appears on the front-panel message display.
3. press the memory/folder button again to reset the AVr's processor.
If the AVr does not function correctly after a processor reset, contact an authorized
harman
kardon service center for assistance.
to locate an authorized service center,
visit our web site at www.harmankardon.com.
https://www.harmanaudio.com/on/demandware.static/-/Sites-masterCatalog_Harman/default/dw409ee4c9/pdfs/AVR700NEW_OM_EN.pdf
Jul 28, 2016 | Harmon Kardon Harman / Kardon Avr 70...
How do i fix a noise problem on 6.1 avr 135 ?same trouble occur on alls channels,a high frequency sound disturbing listening.neither inputsi used(cd-dvd-tape)
There are many reasons this may happen, but without having the unit on the bench, it will be hard to tell. It may be oscillating, which would make that sound. I worked as a Technical Support Specialist for Harman Kardon. If you are interested in repairing your HK, please visit my website at audioserviceclinic.com. Thank you.
Jan 10, 2015 | Harman Kardon Audio Players & Recorders
HARMAN KARDON AVR 142 and APPLE TV
you must contact to the supplier manufacter via ONLINE chat and get support or call to the toll free for the consultation.
God bless you
Nov 25, 2013 | Harman Kardon Audio Players & Recorders
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
Install problems at AVR 142
ensure that you have the reciver connected to a display monitor e.g t.v. set, there you'l be able to make all the necessary ammendments.use the video out or use the HDMI out to connect to your t.v.
which speakers are using for the avr 142?
Dec 24, 2009 | Harman Kardon AVR 140 Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Cheers,
Sergey
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Oct 19, 2007 | Harman Kardon AVR 100
88 people viewed this question
 Grubhead
Grubhead
