Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
My tv stopped working .you turn it on the green light blinks the tv sounds like it is trying to reset but will not come on .could it be a bulb if so I would buy one but do not want to spend a lot of money on a older tv any help wayne
  • wayne lacroix Dec 26, 2012
    I bought a new tv over the holidays but thanks for everyones help .wayne
    Top Expert:
  • RCA Master
  • 14,553 Answers
This model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
Posted on Dec 22, 2012
  • 147 Answers
SOURCE: I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Posted on Nov 05, 2009
SOURCE: rca m50wh725 rear projection tv.
Blinking 5 times means the lamp is dead.
Posted on Jun 22, 2008
Slinteriors
  • 8617 Answers
SOURCE: I OWN AN RCA 52INCH REAR PROJECTION SCREEN
24.95 the kit is called the CP150, CP114 and CP120 capacitors repair kit listedunder RCA reapair kits at www.tvrepairworld.com The kit contains the capacitors and detailed instructions on CD
Posted on Nov 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: 52inch rca rear projection power
Often it will, But the Flyback transformer is also famous for failing in that Model which can cause the same symptom. Caps should alwasy be tried first with that model.
Posted on Oct 27, 2010
electrotech1
  • 1126 Answers
SOURCE: when i go to turn on TV the green light blinks 3
You have lost the high voltage section and the high voltage module will have to be replace or repair, and you are looking at around 450 on repairs.
Posted on Dec 20, 2010
RCA rear projection hd tv 52inch comes on sometimes other time green light goes on then off and then flashes and tv does not come on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the product.....
Jun 22, 2011 | RCA HD52W56 52" Rear Projection HDTV
RCA 52inch DLP TV - D52W17B Lights up, but the...
Your model uses CRTs instead of a bulb. Its usually the deflection board which causes that. Thats about 180.00 for a replacement board.
May 20, 2010 | Televison & Video
I OWN AN RCA 52INCH REAR PROJECTION SCREEN TV...WHEN I TURN IT ON...A GREEN LIGHT APPERARS AND BLINKS 3 TIMES AND STOP...WITH NO PICTURE OR NO SOUND....PLZ TELL ME WHATS THE PROBLEM?...IS IT WORTH...
Nov 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca projection tv 52inch. attempts to come on but it fails. Seems to be the power supply fuse is out but how can we check it without the costly expense?
It not the fuse,all the time it the capacitors are burn.Check for puff up capacitors.Take the back cover off check,check near right the deflection circuit.
Sep 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA TV 52inch HDTV makes a sizzlin sound and shuts off by itself
Your HV transformer (flyback) or HV block is cracked those are common problems with that model. If you want to do it your self heres a link that can help you. go to their site and leave an email about your symptoms.
http://servicemanuals.vstore.ca/
Apr 03, 2008 | RCA D52W19 52" Rear Projection Television
My rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Jan 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
