Question about Miele CVA 4066 Stainless Steel
Miele CVA 4066 machine will attempt to make a cup of coffee but will not dispense through the main dispense
After calling the Miele customer service they told us that the problem sounds like a clogged filter. He proceeded to us to soak the brewing unit in hot/warm water for and hour and then run a "clean brew unit" with the cleaning tab. We followed this, but nothing rinsed out of the machine during the clean, unlike how it did when we had run this before. We are in the process of soaking it again but aren't feeling too lucky. Anyone else have any suggestions?
4 Suggested Answers
  • 128 Answers
SOURCE: I have a three month old Miele CVA 4066. I have
your brew unit is clogged. It will need to be removed and cleaned every 24 hours as per the owners manual. There is a yellow laminated card in the box with the accessories that shows step by step how to perform the 24 hour maintenance. To prolong the life of the brew unit, make sure the coffee grind size lever is in the middle or to the right of center, rather than the left (fine) side. Also, you only want to use dry beans, preferably espresso beans. Oily beans like french roast will clog that brew unit up very quickly.
Posted on Feb 24, 2011
  • 2382 Answers
SOURCE: Miele cva615 says "brew unit
Hi, possible that there is WEARING OFF of the bushes in the shaft of the grinder jar section or to the motor section. If you can try to hold the spindle and move , there must not be any play of the shaft nor it must be TOO free. If so the bushes must be reset with the same type. Also check if the motor bush/bearings are faulty or a drop of light grease or oil might give a temporary relief.
Or else you have to get a another one....
Posted on Mar 31, 2011
  • 1116 Answers
SOURCE: My coffee machine dispenses water from the hot
Try running the maintenance on the sysetm:
Tap until "Maintenance" is highlighted, confirm with OK.
^ Select "Rinse the system", confirm with OK.
^ Select "Start", confirm with OK.
When the main menu reappears in the display, the lines have been rinsed. The appliance can now be turned off.
Do you have the manual for your unit? You really need to clean the dispenser unit which requires a little disassembly, and the manual really explains this well. If you don't, I can send it to you if you provide me your email address.
Posted on Jun 29, 2011
Expresso is too large
Nancy, this setting is controlled by the settings menu. You reach that by right arrowing through the different beverages/menu selections until you select "Settings".
  • In settings, scroll to "program the amount"
  • place a cup under the spout
  • select the beverage you want to program, espresso in this case
  • select start
  • select okay when the amount of water has been used
  • the machine will remember this setting for future espressos
  • the same menu structure allows you to control the amount of coffee ground, as well as the amounts for other beverages
Mar 15, 2016 | Miele CVA 4066 Stainless Steel
Coffee makers Miele cva 4066 stuck on fit jets in central spout
You might need to reset the coffee maker by turning it off and then turn it on again.
Apr 28, 2015 | Miele Coffee Makers & Espresso Machines
When I try to make a cup of coffee, only a small amount of water and coffee come out (like a shot of cappuccino) of the coffee dispenser while hot water is dispensed (simultaneously)...what could be the...
the flow pipe is blocked. you need a nylon thread to clean it out. you push it in and out a few time in the hole until it is clear. shold of come in the kit when bourght new
Sep 22, 2013 | Miele Coffee Makers & Espresso Machines
Milk and milkfroth clogs up after about 4 to 5 cups
It can be several things .. but the first to check is that the milk pipework is not clogged and also that it is fully cleared of milk residue. In other words it may be partially blocked. You need to buy some 'milk line cleaner' ... Miele make it but there are after market products that are cheaper. I use the Cafetto product called 'Pulatte' and it works well but others will do. You need this product for general maintenance anyway. If this does not solve problem then you need to provide specific details on the precise nature of problem.
Aug 16, 2013 | Miele CVA 4066 Stainless Steel
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
What is a miele cva 2650 descaling funnel
The descaling funnel is a small, dull red insert that replaces the capsule holder and is used during the descaling cycle. I purchased a used CVA2650 that came without the funnel. I called Miele concierge service for help. They stock the descaling funnel and sell it for $15.95. In my case, they simply mailed one at no charge without me even asking. Great customer service!
May 10, 2012 | Miele CVA2650 Stainless Steel Espresso...
I have the coffee maker set to 2 cups. After 1 cup of coffee is dispensed I get water for the second cup then the machine keeps brewing a 3rd cup of coffee and a 4th cup of water. So instead of 2 cups of...
Yes you programmed it unaware, the machine will follow what you instruct on it. So change the program setting and try it again.
This advice will gonna help you.
Mar 31, 2011 | Miele CVA 4066 Stainless Steel
Tried to set it up for the first time and the small cup & large cup both flashed ... I pushed the small cup and nothing happened so I turned off machine and unplugged and started again ... still same...
Call Keurig's customer service office. Their customer service rep will attempt to troubleshoot the problem by phone or replace the unit if unsuccessful.
Mar 02, 2011 | Keurig Elite B40 Coffee Maker
I have a Meile CVA 615 coffee maker that has a problem. It is producing lots of liquid in the collection tray on the front of the machine. It is also taking longer to make a cup of coffee and...
It's time to de-scale your machine, please check the bellow link to read the manual and check how to de-scale your appliance:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Jan 17, 2011 | Miele Coffee System
Miele CVA 4066 Stainless Steel Logo
230 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
