Question about John Deere Gilmour Traveling Sprinkler - 4010j
John Deere 3520 NO START
New Batt, checked all connections. Dash lights work but hit key and then nothing. Seems to do this when it has been sitting for a while. HELP!!!
bargainbin2
  • 123 Answers
SOURCE: I have a john deere 430 garden tractor diesel.
Sounds like the fuel pump stoped working.
Posted on Aug 26, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Posted on Nov 10, 2009
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
John Deere la105. When you turn key nothing happen. Lights do not come on in light position and motor does not start. Ignition switch has been replaced. What should I check next?
First thing u should do if nothing is reacting at all is check the battery & BOTH battery connections, ground & positive connectors.
Apr 01, 2017 | Cars & Trucks
On a John Deere 1445 turning the key on nothing works
check battery,fuses and connections --check safety switches --ignition switch and starter for power and connections
Nov 17, 2016 | John Deere Garden
Turn key, no start, dash dead, but intermittent symptons
First I would look for voltage drop of both end of battery terminal.not a look or seem tight . you have to do it (voltage drop) and terminal at alternator.
now does alternator charging. take voltage of battery
if the problem occur have voltage of battery taken
like I read your problem it looks like wiring terminal ground and positive
the noise you hear is probably low voltage to a relay and the dropping voltage make the relay switch inside relay cycling noise click or buzz
Oct 05, 2013 | Chevrolet Cavalier Cars & Trucks
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 | Garden
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
I have a john deere 6400 that wont start from cold even with a new battery it needs jump leads from another tractor and then still struggles the hazard warning light and the information light on the dash...
i had the same problem, it is most likely that your fuel lines are leaking and fuel pump in tank is weak
when the tractor sits for a while the fuel drains back into the tank, thus your injection pump has no fuel in it.i solved it by replacing all the lines and i added electric fuel pump on outside of tank and connected the power to key,when i start the tractor i turn key on for a minuet or so than start the engine ,it solved the problem.
john b
Nov 16, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere 2010 utility tractor, lights come on dash board, but it wont start. Its in neutral, PTO is okay, seat switch okay
Nov 09, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Seems like the car is staying in "ACC" (accesory key position)
BFC that body function controller. BFC batt fuse controls .the body function controller .its part of the PCM.the BFC controls anti theft system. your interior lights -drl lights- radio -door locks.if your check engine light is on take it to dealership.because your BFC and PCM works together. your car could shut off. that unsafe.when you on a busy highway.you have electrical problem.not a home fix.
Jun 27, 2009 | 1999 Oldsmobile Alero
John Deere Gilmour  Traveling Sprinkler - 4010j Logo
67 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
