Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
My stove is saying FE32 - Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Stoves 700gdo
I couldn't find your exact model but I think the instructions on here should be the same. I would appreciate it if you can post back to say that they are or aren't thanks. http://www.stoves.co.uk/media/549813/SGB600PS_SGB700PS_SGB900PS-2-.pdf
Jul 12, 2014 | Tecnik Ovens
Oven stopped working
If you are saying that the breaker in the breaker box has been tripped, then there is a problem with the circuit or in the stove. The circuit may be checked with a volt meter. If the problem is in the wiring circuit, the breaker will trip with the stove unplugged. The problem is most likely in the stove, and the stove's wiring needs to checked. If you are unfamiliar with 230V wiring and how to safely test the wiring, have an appliance technician service the stove.
Apr 15, 2014 | Ovens
Why did the inner door of the stove shattered
I got technician locally to came and sort out. He says it can happen but often but there is a chance and I was the unlucky one.
Jan 09, 2010 | Stoves Premier 600GRa Gas Single Oven
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
Need to adjust clock setting on Stoves 900 GDO Stoves 900 GDO gas double oven
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
Mar 06, 2009 | Stoves Ovens
MY STOVE
hi thanks for the question .F3 on a Frigidaire stove means that the oven sensor is open that's the part in the oven to the left and top it looks like a pencil replace part from the back of the stove but with 1 screw holding the sensor replace BUT power off please thanks the appliance doc
Sep 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
80 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
