Question about DeLonghi Heating & Cooling
DeLonghi Dragon space saver oil fired heater plug overheats
I have had this heater for about 6 yrs during which time it has had very little useage. Recently the plug and metal prongs have been getting very hot so much so that I have burnt my hand on the plug. The heater itself works fine but I can't use it with the over heating electrical plug as I feel sure it is not safe. I have used other electrical items from the same electrical socket and all have worked fine with no heating of the plugs on them so the fault is obviously with the heater/ plug itself. Any help with what could be causing this would be appreciated and advice on how to fix it.
SOURCE: Delonghi "the incredible heat machine" started smoking
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Posted on Feb 10, 2008
SOURCE: Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Posted on Apr 02, 2008
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
  • 19396 Answers
SOURCE: instruction manual
Here are the instructions: DRAGON HM3
If the model is different , download from:
Select your product, insert model and download instructions here
Posted on Nov 25, 2008
  • 89 Answers
SOURCE: Delonghi Dragon Two, oil filled rad trips the main elec fuse
If it is tripping the breaker in the panel, there is a direct short in the heater. Scrap it before it causes a fire. Seriusly
Posted on Nov 01, 2009
Delonghi dragon 3 not working beep
The appliance beep's to indicate a malfunction. My manual say's to contact the De'Longhi customer service.
May 20, 2014 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
I would like to obtain a instruction manual for the DeLonghi Dragon 2 oil filled radiator. Do you have an address, phone number or place I can contact. Thank you,\r\nPeter Knight
If you live in the US, Call Delonghi Customer Support @ 800-322-3848.
If you live in Canada call 888-335-6644
If you love in Mexico call 800-711-8805
That should help you, Peter.
Apr 19, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Hi i have a new DeLonghi Dragon 3 heater. The timer seems to work opposite to your instructions - i.e. the instructions indicate that the notches must be pushed to the outer ring to indicate the operating...
This is from the instruction manual online:
To set the heating periods proceed in the following manner:
- Check the time by your watch. Supposing it is 10.00 a.m. turn the numbered dial of the
time-clock in a clockwise direction until the number 10 coincides with the reference mark s
on the time-clock. Set the time period during which you wish the appliance to work by
pushing the notches towards the centre. Each notch corresponds to a period of 15 minutes.
At this point sections will be visible corresponding to the working periods.
Set in this way the radiator will function automatically every day during the set period.
(Important: the plug must remain connected to power supply).
- To change the programmed time period, just bring back the black notches to their original
position and set the new working periods required.
- If you wish the appliance to function without programmed working periods push all the notches
towards the centre. In this case, to turn the appliance off totally the plug must be pulled
out apart from switching off, so as to avoid unnecessary working of the timer.
Jan 29, 2011 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Delonghi dragon oil filled heater with timer. How does the timer work, is there a way to set it so that it stays on all the time? Do not have the manual
Within the timer is a 3 point switch. Push the switch to the end closest to the arrow and away from the clock icon. It will stay on
Oct 04, 2010 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Oct 24, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Left Heater switched on over night, oil radiator de longhi dragon
1st, check the electrical cord plug; because of the hielectric demand, thesaes plugs overheat and form a burn coating on the prongs that stops the hilevel of electric but allows a small level ofalaectric that still lights the lights but no power for heat.
2nd, the thermostat is not making contact: it is a bi-metal contactor that sometimes burns or loses its strength and no matter where you turn it it wont work. You can simply cross the terminals of the thermostat to see if you get electric flowing (you have to open the oen housing to do this.
3rd, the element could be burned-out or (as often happens) the connection to the heat element burns-off. Again, you need to open the end housing and look, or take it to a small appliance repair place.
Oct 11, 2009 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Actual output on settings
1. 900 WATTS
2. 1.1 KW 1,000 WATTS WHICH IS ABOUT 1.096 WATT
3. 2.0 KW 2,000 WATTS
Nov 25, 2008 | DeLonghi Dragon 3 1025 / 1025T Oil Filled...
Heating & Cooling Logo
67 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
