The battery will hold a charge but when we try to start the car it wont start most of the time and it drains the battery. Checked the starter and the alternator, they both checked out fine. Sometimes the car will start, but its getting worse, so it wont start as much anymore. Any ideas of what it could be?
CAR NO START PROBLEMS:----- It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue. From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:----- What to Do When Car Turns Over But
Won't Start? http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html ----------- http://technoanswers.blogspot.in/2012/02/car-starting-issues.html ------------ http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html -------- http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html ---------- http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html --------- http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html ----------- http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html ---------- -------------- -------- http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html ---------- --------- http://www.howtorepairguide.com --------- These will help. Thanks.
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
Check your fusible link on your positive battery cable going to starter,wire could be burnt or melted,follow positive battery cable.
