Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Refrigerator humming a lot louder than normal. Is it a cause for concern?
    Top Expert:
  • Electrolux Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 29, 2012
Loud humming or buzzing only when it spins at high speeds
This noise causes by the drum bearing is getting worse. As soon as the noise is getting far louder and extremely louder then you have to replace the bearing of the outer drum. Normally, the repair cost is as high as buying a good deal new washer.
Oct 14, 2013 | Whirlpool Duet 4.0 cu. ft. Washer
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
Sub zero. 650 reefer. Significant hum coming from top mounted compressor, but still marginal cooling. Now a louder hum and unit no longer cooling.
Hi roger,
I see you concern, and if the unit does not cool anymore and there is a humming noise then you will need to replace or have your compressor repaired no doubt.
Have a nice day,
mvincentc
Jul 03, 2011 | Kitchen Ranges
Our Maytag upright freezer motor is making a louder noise when it runs. It used to be a quite little hum, now I can hear it through the wall in the next room. What should I do, It has a 10 year warranty...
try to clean your condenser unit or check your condenser fan if working normally possible your comp.working hardlydue to poor circulation of air cause of high pressure of unit.or possible wear and tear of mechanical parts of long years of uses need for replacement of compressor.
Mar 06, 2011 | Refrigerators
Sharp winning or piercing compresser noise. is it normal? maytag refrigerator model # ptb1954grw.
maytag frig is noiser than other brands . amana also and jenair and majic . all made by maytag. this units have a compressor noise louder than most . there comp are larger and some what louder . but i would say you have a normal maytag .. mm i was maytag largest dealer in utah for many years and your statement is very common .. some times the copper lines or fans cause louder noises . so if to loud you should have ti ck'ed . mm
Aug 10, 2010 | Maytag Refrigerators
Fridre is about 9 years old. For the last couple of weeks it's been making louder than normal humming noises and the temp is not cold, even when the thermostat is at it's coldest, same with the bottom...
the wind tunnel in the frezzer is iced up, therefore the fan is rubbing against the ice creating humming noise. solve this by defrosting and replace fridge seals before u get sick and die! food poision is bad. termostat should work, but may need be replaced.
Dec 16, 2009 | Fisher and Paykel Refrigerators
Motor running a lot
9360gabbs,  The significant thing that you list is... it is louder than usual.  You indicate that you have cleaned the coils under refrigerator.  Try and roll the refrigerator out from its normal location so you can get behind it.  Remove the cardboard or metal cover across the bottom area of the refrigerator.  Check and see that the fan next to the compressor is running and that the blades are clean from dust, etc. Sometimes the condenser fan dies and must be replaced sometimes the blades are covered in dust, etc and causes a decreased volume of air to be moved by the fan.  Make sure the entire area is clean from dust, etc.  Be sure to replace the rear cover that was removed.  Very important!  Hopes this helps you! HandyHenry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
192 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
