Question about ASUS Computers & Internet
Keyboard/Interface error ASUS P5Q-SE2 Motherboard on boot up
I have an ASUS P5Q-SE2 Motherboard and on boot up I get a message Keyboard/Interface failure Please enter setup to recover BIOS settings Press Del to enter setup USB device over current detected !! System will shut down in 15 seconds And the system shuts down. When I reboot and hold the DEL key down to get into setup, I get the same message. I am unable to get into setup to restore the BIOS. Do you have any suggestions how I may fix this problem?
nai6378
  • 58 Answers
SOURCE: cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Posted on May 11, 2008
steve6375
  • 395 Answers
SOURCE: Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Posted on Aug 08, 2008
Hanto
  • 226 Answers
SOURCE: bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
Posted on Aug 12, 2008
  • 42 Answers
SOURCE: system shutdown in 15 seconds
hi, pl check for viruses, scan the system, and go to cmd prompt and issue this commnd at c:\ shudown -a and press enter to disable reboot and scan the system and check any hardware issue.
  • 508 Answers
SOURCE: System shutdown in 15 seconds
Shut the power down to the computer all the power and pull the power cord out, remove all usb devices except the mouse and keyboard, Turn the unit back on and see if this fixes the problem, if it doesn't then you will have to go into the computer and clear the c-mos this will allow you to get into the bios screen from there you can set up the computer again. Check you manual for the instructions on bios reset, most times it is just pins 2+3 that need to have a jumper installed to reset it. READ THE MANUAL PINS 2+3 APPEAR ON MANY THINGS ON THE CIRCUIT BOARD
Posted on May 31, 2010
Ihave ASUS M2N68-AMSE2 nmotherboard- on starting up, my computer shows ASUS green screen for ages and nothing happens, I press reststart, motherboard boots up and starts windows
hardware related issue, check your bios settings to see if halt on errors in enabled, also disable
the ASUS splash screen, you should be able to see the initial boot error..
Feb 19, 2011 | ASUS M2N68-AM SE2 Motherboard
I have a asus m2n68 am se2 motherboard..when i restart my computer my keyboard do not work.it gets detected but does nt functions..pls help me
Is your keyboard directly connected to your computer or is it wireless? What OS are you using? (XP, Vista, Win7). If the keyboard is connected to a USB port, try plugging it into a different port.
Dec 09, 2010 | ASUS M2N68-AM SE2 Motherboard
How do i change from 32 bit to 64 bit on a asus p5q se2 motherboard
The only way to Upgrade from 32 bit to 64 bit is to buy a 64 bit MOBO and replace it with the 32 bit MOBO.
Oct 05, 2010 | ASUS P4P800SE Motherboard
No beep, no display in new asus m2n68-am se2 motherboard
Try booting the system with a bootable and well memory stick and probably check the power switch if it send any signal to the board while pressing it.
May 07, 2010 | ASUS M2N68-AM SE2 MicroATX Motherboard &...
Asus P5Q Green LGA775 motherboard information
I don't see a question but try one of these links:
www.wikio.com/product/asus-p5q-120332.html
www.alvio.com/xABK_PID598601_p5q-green_asus_asus-p5q-lga-775-intel-p45-atx-motherboard-retail.html
Oct 07, 2009 | Computers & Internet
Asus P5Q Upgrade disk error
take the cabel from the dvd out...and try to start igen.
Or try to fixboot with your windows cd...
Apr 11, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
I just bought the Asus P5Q SE2 motherboard last night and when I went to boot up I got a blue screen error. I called support and he told me to take out one stick because I was using 4gb and use only 2....
Well, first of all, you need to know that the sticks are OK
Download a program calles Memtest86, there is a free version of it to download here
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441115&lc=en&cc=us&dlc=en&submit.y=3&submit.x=5&lang=en&cc=us
Now, do as the memtest manual say and test your sticks one by one, if they are OK then you know its your new MoBo causing the problems.
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 18, 2008 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
Computers & Internet Logo
510 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
