Question about Fujitsu LifeBookS6120 Notebook
Error code 020 stuck key 35 - Fujitsu LifeBookS6120 Notebook
Chevy Cruze error code 91
ya i know that what is error code 91 it is that ur car key is not there & if shows error code 35 then ur car remote key cell losing his power exchange with that cell & ur car is ok
Jun 02, 2013 | Cars & Trucks
Frigidaire agq7000es0 gas dryer generates an e-68 error code. have cleaned the lint area. still get error message. the dryness button seems to have gone haywire.
This error code E68 indicates that a button or key is stuck. Press the buttons/keys repeatedly one at a time to possibly unstuck the key/s. It may also help you find out the stuck key/s as it will click differently from the good keys. You need to find and unstuck the key manually by accessing the control board if the error code still persists. Click on the link below for the detailed troubleshooting instructions of this error code.
Troubleshooting Error Code E68 on Electrolux/Frigidaire Dryers
Jun 18, 2011 | Dryers
Has anyone got the codes for starview box please im stuck!!
CW Keys 5C01 updated 08/10/09 10:35
00= C5 BE AF 36 0A 61 91 AA
01= D2 D1 80 FA 21 85 0F 53
TW Keys 5A01 updated 08/10/09 10:35
00= 83 5D 12 B8 96 F6 1F C4
01= D2 F9 35 22 0C A7 D6 C9
NTL Keys 5401 updated 08/10/09 10:35
00= F0 0E 91 E0 2D C1 C5 FD
01= 5D 61 B2 C8 E7 DD F9 57
Oct 08, 2009 | Intel CPU
I am getting an error code on my CS-1500 that says C-6 then 020. Unplugging and restarting do no good. Any idea what's wrong? Tom
That is a HIGH temperature detect error code.
Check the thermistor, if you measure 0 ohm resistance in the thermistor, replace it.
Press the stop/clear key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down.
Press the stop/clear key.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys.
Go to U163 and hit the Start Key, this will reset the trouble code.
Sep 11, 2009 | Copystar CS-1500 Copier
I just changed the toner and I now have an error code 020
020 is a CU rom error... check that your memory and PS cards are fitted into the main PCB properly, if not remove the PS card and try it. Beyond that you might have a faulty main board
Sep 08, 2009 | OKI B4350 Laser Printer
PCR T2000A error code 35 (change exceeds preset limit)
Hi. I've never had that before. Someone has probably set an obscure change limit in the machine features. Try this:
Turn key to program mode.
0
CASH
SUBTOTAL
SUBTOTAL
0
CASH
SUBTOTAL
Turn key back to REG and try it
Mark
SUBTOTAL
May 05, 2009 | Casio Parts Cash Register PC Desktop
Need codes to program remote for sanyo tv.
I've got the three digit code, you may have a remote that requires a 4 or 5 digit code. However 166, 007, 020, 053, 082, 187, 266, 347 are all the 3 digit codes.
Mar 13, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Mar 26, 2008 | Office Equipment & Supplies
'stuck key' on IBM ThinkPad 390E (2626-DOU)
goto the device manager and uninstall the keyboard and restart the system. check that the error is still coming..
If still the error remain same ...shutdown the system and power off and just clap the each and every key of the keyboard to release the keys if any stuck. Check that error by rebooting the system. Hope that the problem is solved.
If still not then maybe the keyboard is going bad.
Cheers - Parveen
Feb 10, 2008 | IBM ThinkPad 390X 2626 Notebook
Fujitsu LifeBookS6120 Notebook Logo
139 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
