Question about Hardware & Accessories
Noma digital timer cat td1000
Lost programming instructions
  • 5,245 Answers
Copy following link to help identify timer and download possible manual.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Oval
Timer brand numbers and designs change.
Add a comment and describe timer in detail if your timer does not show on link above.
Posted on Nov 29, 2012
SOURCE: how to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Posted on Oct 05, 2010
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: instructions for NOMA N1507 timer for programming -pls.
N1507 manual:
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and let me know if these instructions are accurate
Posted on Dec 05, 2010
SOURCE: LOST INSTRUCTIONS NOMA OUTDOOR TIMER # ET525C
UPM makes ET525 timer.
http://waterheatertimer.org/UPM-timers-and-manuals.html
ET525 manual is 3.6 MB and takes a bit to download on lower speed connection.
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Posted on Dec 12, 2010
SOURCE: i lost my instruction on how to programe my noma
Noma is Woods timers.
See all Woods timers and manuals
Add a comment any time
Your timer could be Woods/Noma N1502
http://waterheatertimer.org/pdf/Woods-N1502-manual-english.pdf
Coleman 2001
http://waterheatertimer.org/pdf/Woods-2001-49647.pdf
Woods 13660
http://waterheatertimer.org/pdf/Woods-13660.pdf
Woods 59730 yard stake:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Coleman/Woods 13547 yard stake
http://waterheatertimer.org/pdf/Woods-13547.pdf
Posted on Dec 13, 2010
I lost the instructions. How do I program these? I have 2 of them.
Question posted under oval-shaped programmable timer.
There are several oval-shaped plug-in timers.
Open following link to identify timer.
Typical manual for oval-shaped timer may apply to your timers:
http://waterheatertimer.org/pdf/Noma-TD1000.pdf
If this is not your timer, then add a comment and describe timer in detail.
Add a comment for more help
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 17, 2011 | Woods Indoor 24 Hour Digital Timer (59203)
HOW DO i SET THE WOODS 59203 TIMER LOST DIRECTIONS
Woods timers and manuals:
The picture shown at fixya for 59203 is not correct.
Picture shows 49112 which is also TD1000:
Manual for 49112-TD1000:
Manual for 59203:
http://waterheatertimer.org/pdf/Woods-59203.pdf
Manual shows 15 steps.
Plug timer in to charge battery. If battery will not charge, then timer is bad.
Set current time.
Set program1 ON time.
Set program1 OFF time
Set program2 ON time
Set program2 OFF time up to 20 pairs of ON-OFF times.
When programming is complete, press ON/OFF/Auto until Auto shows in display.
Add a comment of you need help with specific programming.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
Hardware & Accessories Logo
160 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
