Question about Hifonics Generation XI Thor Car Audio Amplifier
Gets very hot and do not turn on
When i hook it up it gets very hot and burn the fuses,
  • 55 Answers
SOUNDS LIKE YOU BURNT UP THE POWER OUTPUTS IT'S UP TO YOU WEATHER YOU WANT TO BRING IT TO A REPAIR PLACE
IT MAY COST ALOT TO FIX GOOD LUCK
Posted on Feb 21, 2009
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
Why does my maytag dryer when turned on get red hot instantly, yet the motor only humms?
quit buying parts ur motor is shot and u should be or soon be smelling a wireish burning smell.
Oct 08, 2014 | Maytag Dryers
On my 91 dodge dakota my friend was giving me a boost and he hooked the cables up wrong he but the hot on the ground and the ground on the hot now it will not start i power to lights and everything else...
Sure all those big 20-50 amp fuses are ok in the underhood box?
You can't check 'em with a testlight,removal and a continuity test is best.I don't think that truck has the old wire type fuse link on the starter,but I would look for that also.It also seems like on the older dodges the power all runs thru the ammeter , if it has one check to see if has burned out.
Dec 29, 2013 | 1991 Dodge Dakota
Checked blink rear right probe touched blue and green wire and now the gauges dont work tail light brake and turn no blown fuses 2000 cbr 600 f4
you must have blown fuse. blue wire is hot and green is ground. if you hooked these together you either burned wire or fuse
Oct 29, 2013 | Honda Motorcycles
Hooking electric wheelchair battery to the fuse box and when the positive touches it sparks and smokes....whats wrong
tiny spark sometime normal but not getting hot! batteries are hooked up wrong. check polarity double double double check them
Oct 18, 2012 | Pride Jazzy 1103 Ultra Standard Power...
Cant figure out how it hooks up. Directions a really bad. It has a solid wire running to all fuses,a red wire running from fuse to switch and a black wire running out of switch. Where the hell do i hook...
You hook your HOT wire from your battery to the + terminal on the switch.
That HOT power goes through your fuse to a switch, when you turn the switch ON. the other wire from the switch gets HOT. This wire goes to your device.
So there is only one HOT wire connection. This is split by the panel to the six fuses and then the six switches. Wire from the switch to the device, such as anchor. The anchor motor must also be grounded to the negative of the battery either directly or through a grounding system like in a car.
Gary
Jul 26, 2011 | WHITECAP 6 TOGGLE SWITCH PANEL
Whirlpool dryer
it could be a bad limit switch (metal thermostat) that turns the heat off when getting too hot. if the heat continues too much it will burn out a "fuse" in the back of the machine and it will not turn back on. so if you replace the "fuse" then make sure you replace the limit switches too or the "fuse" will burn out again.
Apr 05, 2008 | Whirlpool LEB6200 Electric Dryer
Hifonics Generation XI Thor Car Audio Amplifier Logo
106 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
