Question about Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts
I have a marley M602W model line voltage thermostat no instructions how do i connect it
  • Russ Prestipino Dec 01, 2012
    it has two red and two black. I believe the reds are the hot from the panel and hook up to the black and white (240)the blacks tan go to the heater Is this correct?
2 Suggested Answers
SOURCE: marley md26 line voltage thermostat
The Black Wires from the md26 are your load(the heater) and the red lines are your line(power). The lines are also paired up on the thermostat with a red and black on the left and are red and black on the right. In the actual heater connect the black to the black wire and the white to the white and connect the grounds. In the thermostat connect the black from the heater to left side black( remember there are pairs left(black, red) right (black, red) and the white to the right side black connect the black from your power to the left side red and the white from your power to the right side red. Should be ready to go.
Posted on Nov 19, 2008
How do i wire a 240volt hydronic base board heater and thermastat
I need a control knob for my Marley electric wall heater model#fzl3004b
Dec 17, 2012 | Marley Electric Hydronic Baseboard Heater,...
Marley IUH524 Heats but no fan
high limit not working , not letting fan come on try jumping it out to see if it works
Feb 11, 2012 | Marley IUH524 Electric Heater
Hello Fixya Guru ! I am in the process of installing several Marley PLF series 2000 watt/ 240 volt electric "Hydronic" baseboard heaters. I am using 10/3 bx with a 30amp breaker. To my...
You are correct that these heaters use a two-wire 240 volt supply, and the neutral is not needed.
2000 watts = 240 volt x Amps ==> Amps = 8.3 amps
30 amps x .8 safety factor = 24 amps
24 amps / 8.3 amps = 2.9 heaters per 30 amp breaker (3 heaters should be okay)
More info, pls let me know.
Charlie
P.S. Where does the 2880-watt number come from ?
P.P.S. There has to be a ground bus-bar in the panel -- if it's a main panel (not a sub-panel) the ground buss and the neutral buss are connected in the panel. Could you clarify what you have in the panel.
Jan 11, 2011 | Fahrenheat Electric Convector Baseboard...
I have a large room in my basement where I would like to install four Marly 58" baseboard heaters to work off one thermostat. The units are rated at 1250 watts each for a total of 5000watts. I plan to...
Using the equation I = P/E where "I" is Amps, "P" is Watts, and "E" is voltage, we find that your 5000w circuit will have an Amperage of 20.83. A 22 amp tstat will work, it will just leave you no room for surges. I would suggest splitting the baseboard and using 2 thermostats. Hope this helps
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
I need to know how to wire the thermostat to the 30" Fahrenheit baseboard heater
if its 240v your line in to the thermostat is two hots (black and white, white in 240 is no longer nuetral and must be marked as hot) and a green/bare ground from the panel, these usually connect to the reds on the double pole thermostat. the load out is usually two black wires which are then connected to the black and white wires of the baseboard unit.
Aug 21, 2009 | Marley Heating & Cooling
Add line thermostat to fahrenheat space heater
Just disconnect the other thermostat. You can leave it there just disconnet the wires
Nov 30, 2008 | Marley Electric Hydronic Baseboard Heater,...
Marley md26 line voltage thermostat
Nov 08, 2008 | Marley Electric Hydronic Baseboard Heater,...
Marley Electric Hydronic Baseboard Heater, 58" 240V/1250 Watts Logo
118 people viewed this question
Top Marley Heating & Cooling Experts
Paul Carew
Ron Durham
Are you a Marley Heating and Cooling Expert? Answer questions, earn points and help others
