Question about Refrigerators
Icemaker I hooked up a waterline to the ice maker for the first time, kenmore 253.74832406. Made only batch of ice and notworking. Any suggestions?
    Problem Solver:
  • 9 Answers
Pull the front cover off the ice maker and force a harvest to see if you now get water. Also if the freezer is not 10 degrees or less it will not cycle. Jump "T" to "H" with a pice of wire stripped back 1/4" on each end. You only need a very short piece of wire. Leave it in the two holes for 15 seconds to see if a harvest will happen and if it will again fill with water.
Posted on Jan 10, 2009
Kenmore icemaker not working and freezer frosting up
Freezer temp has to be 10 degrees or less for ice maker to work. Door gaskets ok and not leaking moist air into freezer? Defrost mechanism working?
Aug 28, 2017 | Kenmore Refrigerators
Have a new frigidaire how long does it take for ice bin to fill after waterline install
Ice maker will call for water 12-14 hours after plug in. If the ref was running and then Waterline was connected it should call for water in 4 hours or less. Easy rule, after 24 hours, ice bin should be full.
Dec 05, 2012 | Refrigerators
The icemaker won't make ice , the fridge is about 19 years old.
Put some water in the ice maker. If it makes a batch replace the water valve. If ice is already in there then replace the ice maker. Service manual and more HERE
Apr 06, 2011 | Kenmore Refrigerators
Model 501-78353 dispensing water but icemaker has not worked since it made one very large batch of ice and the lever rose - I guess to stop the icemaker
yes the lever needs tp be push lightly down and then the ice maker will be in on position again. then the ice maker will call for water then it should start making ice in a few hours.
Feb 13, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Is there a shut off valve on the ice maker?
There should be a shut off valve at the beginning of the water line that the installer tapped into when installing your icemaker. Mine runs down through my kitchen floor into my laundry room and is tapped into a copper cold waterline with a small handle attached to it.
To stop icemaker from making ice simply raise the lever to the up position that is attached and hangs next to your icemaker tray. This works on most models.
Aug 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Even though I connected the waterline,there is no water in the ice maker. the icemaker keeps turning to dispose the ice it does not have. Thinking that the end of waterline was frozen, I unplugged the frig...
BACK OF THE FRIDGE IS THE WATER VALVE. UNPLUG THE OUTLET WATER OF THE VALVES, LEAVE THE INLET CONNECTED. APPLY 120 TO THE VALVE AND SEE IF WATER COMES OUT. MOST LIKELY YOU HAVE TWO VALVE, WATER AND ICE. IF THEY BOTH WORK, YOU HAVE A BAD MODULE IN THE ICEMAKER
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore 64802 Top Freezer Refrigerator
Ice maker not hooked up (on purpose). The ice
Sounds like you are not going to use the automatic icemaker, so I would remove the whole icemaker unit which will include disconnecting the wire harness behind the icemaker which will shut off power to the icemaker and will also give you more storage room in your freezer compartment.This will not harm the refrigerator or the icemaker, you could also disconnect the waterline if you want.Please note that this solution applies to the top freezer,and bottom freezer style refrigerators only thatt DO NOT have dispensers through the door. Good luck !
Dec 02, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I hooked up my refrigerator and my ice maker to work. I've checked the waterline. But no water comes out of the dispenser and no ice is being made.
i had the same problem one time and there was something obstructing the fan under my frig and i blew thru it to icemaker with compressed air and it started working
May 17, 2009 | GE GSS20IEP Side by Side Refrigerator
I want to install my icemaker it is not working
Pour some water into the icemaker and wait for a sign of ice production. If it makes a batch then fails to produce anymore then check that water valve. If it does tose out any ice at all then check that ice makers connection or get another. Give that puppy 24 hours to start making ice. Read more
Apr 09, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
