My Dual 32" lcd tv, model number dlcd3221 will not switch on, i have tried the fuse and its ok, i switched it off before going o bed and when i tried to switch it on when i got up, it wouldn't come on and it seems like there is no power going through it as not even the stand by light comes on
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
Posted on Nov 11, 2007
SOURCE: Olevia 337 B11 Power Problem
Same exact problem here, although my TV managed to last 1 & 1/2 years. Now its dead. THAT was almost worth the price! ($700)
Posted on Jul 26, 2008
Shuttle83
  • 1139 Answers
SOURCE: technika lcd 32
Hello hibbie,
I gave this advice on another post, it applies in this case too so here it is:
This is an indication that there may be a problem in the power supply, possibly bad capacitors, and or defective active components. I would suggest first checking to see if there are any blown fuses, and or loose connections. Past this point I would advise that you either take the TV to a TV repair shop or have a TV technician troubleshoot the TV in home to determine the problem it is having.
I hope this helps,
Thank you,
Shuttle83
Posted on Aug 10, 2008
  • 157 Answers
SOURCE: Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Posted on Sep 11, 2009
dave1645
  • 834 Answers
SOURCE: My Model LN32A330J1D LCD TV will not power on even
you have a blown capacitor in the power supply
the little can like cap will have a puffed up top ewplace it or have it done and you will good to go
Posted on Sep 23, 2009
Technika lcd 32
Probable power supply failure.
Jan 13, 2014 | Televison & Video
I hav an LC AQUOS TV Model Number LC-C3234U..The power button keeps going off and blinking green..tried holding power button down but it comes on yellow and then goes to sleep blinking green again..wh
These blinks are fault indications. Count the number of blinks occurs at one time switch on, and check this link for details. The link contains the blinking codes to many brand TVs.
Jan 29, 2013 | Sharp Aquos LC-C3234U 32 in. LCD TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Hd tv got sound but no picture
Switch off the TV. Disconnect all the cables. Wait for some time. Reconnect all the cables and ensure they are not loose. Switch on the TV. It should work now with both picture and sound.
Jun 15, 2011 | LG 32LC51 32 in. HD-Ready LCD TV
Dual dlcd3221 hd tv cant find on win7 pc when coneccted thru hdmi lead worked before just stopped working
it may require you set up duel displays in the video control panel menu mine worked for abit and then stopped requiring me to set it up there
Dec 21, 2010 | Televison & Video
LC320EM8A 32" TV WON'T COME ON NOT BY REMOTE (NEW BATTS) NOT BY TOP POWER SWITCH. WORKED LAST NIGHT NOW NOTHING, TRIED THE ONE SUGGESTION IN MANUAL TO UNPLUG FOR 30 MINS TO RESET(?) ALL POWER CONNS...
Hi Wayne,
I'm glad your getting somewhere with your research. If you arent getting even a standby light, try checking the plug fuse and if this is ok, then the power supply board inside the tv is faulty. Could even be the power pcb fuse or dry capacitors (bulging tops on faulty ones). Hope this helps, and good luck :)
Feb 14, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Sep 11, 2009 | Televison & Video
Samsung syncmaster 914
You can have a look at THIS parts shop for switch board of your TV or mention the model number of your samsung TV to help you out.
Oct 02, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
PROBLEM WITH TV
if your cable signal is poor , noisy, then it may not switch channels easily or at all.
Feb 17, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
