Question about Kitchen Ranges
I have a Brandt kwe19x1u range style cooker and the timer is not allowing the main oven work. I do not have the manual still and am unable to figure out the timer. Please help
The timer is not allowing the main over work, I did get it working but the timer turned it off after 30mins. Is there a manual I can get for this model, it is a simple problem and not worth replacing
  • 209 Answers
SOURCE: smoke from oven
I am a recently retired appliance engineer of 20 years sounds like pure coincidence, check the fan for circuit at terminals, and / or check for movement of blades, that you have not got fan jammed, replace fan motor unit if needed, still cheaper than a call out if i have helped rate me work with safety all the time, unplug at all times when working on any item
Posted on Sep 09, 2007
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
  • 13 Answers
SOURCE: User Manual for Belling Electric Cooker
The clock is flashing zeros because you need to set the clock timer.To do this you need to press and hold in both of the the cook period and end time buttons together, then with both buttons still held in , press either the "+" or "-" buttons to set the correct time of day
Posted on Apr 21, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
Can i by pass the clock or timer to be able to use the main oven they are worked by electricty
Cooker dead or oven not working or clock flashing - YouTube
? 3:05
https://www.youtube.com/watch?v=FDz4UpFMXq0
Dec 20, 2011 - Uploaded by Richard Saupe
Can be quite a problem when your cooker or oven is dead and always ... want to use it. watch this video on tips to re set theclock and get it up and ru. ... I try to set time I'm after a video clip on how to change the timer any help .
My Rangemaster 110 oven will not light, the timer/clock is ...
www.howtomendit.com > Kitchen Appliances, Gas Cookers
Free repair help - rangemaster 110 oven will not light timerclock broken too. ... I turned off mains electric then took out the 5 screws .... all I was interested in was bypassingthe timer and not fixing the timer -like others ..... Like I say, you will have no clockfunction but will be able to use the oven in the way it was meant to work.
Nov 24, 2015 | Kitchen Ranges
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Main oven won't work
On ours you have to use the the timer controls; press the button with a hand symbol and the one next to it with a "-" symbol at the same time. Try a combination of the buttons on yours if this doesn't work. Weird, and took me months to figure!
Jan 12, 2009 | Tricity Bendix SE454 Electric Kitchen...
Flavel Milano 100
Hi all...
Yep got the main oven gone......
Lucky iam good with electrics, got my brother in law to double check Qualified Elctrician it turns out that its the Thermal Fuse that has gone have ordered a new one at the cost of £8.......
This range is made by Beco thats why its hard to find info on the cooker.. The grill/fan oven has thermal fuse as well.....
Hope this helps MVE
Aug 11, 2008 | Kitchen Ranges
My Tricity Bendix Strata SI 530 main oven does not work. The light in it also doesn't work. The top oven does though. Looking at the manual it suggests that the timer could be the problem, but there...
areas to look are:
oven selector switch and thermostat
mains terminal block - where mains input is connected. these can quite often burn out.
overheat stat
Jun 24, 2008 | Kitchen Ranges
Cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
Feb 14, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Hi
Oct 23, 2007 | Kitchen Ranges
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
