Question about LG 37LC2D Television
Whining noise at rear of tv - LG 37LC2D Television
My 2005 Chrysler town & country is making a whining noise and gets louder when I accelerate. Also my light is on for rear defroster, but it doesn't defrost. Help!!!!!!
If the whining noise is coming from under the hood, have all pulleys checked for wear. ( Alternator/tensioner/idler etc ). A bad pulley will whine. As for the rear defrost, check the wires that go to the back window. There will be one on each side of the rear glass. One may be seperated/broken from the glass causing the defrost not to operate
Jan 21, 2016 | Chrysler Cars & Trucks
1999 Mitsubishi Eclipse whining noise from the rear when accelerating
A whining noise during acceleration usually, is from the gear set, indicating the pinion is too close to the ring gear.
I believe the eclipse is a FWD car though. Could it be the transmission you are hearing?
Nov 11, 2013 | Cars & Trucks
Rearend prob.[noise]
Here are the common causes or rear end noises
Constant high pitched whine at all speeds: Pinion Bearings or Ring gear carrier bearings
Whine at steady speeds or whines on deceleration: Rear end gear set is worn and will need to be replaced.
Rumbling type of noises are caused by wheel bearings or a tire with a separated cord.
Jan 19, 2011 | 1999 Suzuki Vitara
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a RCA Scenuim Rear Projection TV that is 3 years old. It has a loud whining noise coming from the back. What is causing the noise and is it worth fixing the tv.
it is being caused by the flyback tranformer or hi voltage transfomer
if the part is still avail it is cheap but the labor will knock ya down in most case 250 +
Sep 28, 2009 | RCA HD52W58 52" TV
TV makes very loud noise
Ur high voltage transformer is dead,the FBT,the big block of plastic have red wire go to the video board.Also might have burns capacitors in the DM power suply board or deflection board it puffed up.
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
ABS Light Came on and Loud Whining in Rear End?
Well you can remove the sensor in the diff and make sure that looks ok they g obad quiet often also woulnd not hurt too remove the rear diff cover and inspect the rear end if it is whining and you dont see anything wrong i would refill it with lucas oil/grease and start praying check the pinion too and see if it has any play in it
Jan 17, 2009 | 2004 Ford Ranger
Whining noise problem and color flickering
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | RCA HD50LPW165 50" Rear Projection HDTV
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
65 people viewed this question
Computer Repairing
Computer Repairing
