Question about Polk Audio PSW202 Subwoofer
Polk Subwoofer has Power But No Sound. - Polk Audio PSW202 Subwoofer
2 Suggested Answers
  • 40 Answers
SOURCE: Optimum set up for Polk Audio PSW 10?
Run 2 RCA cables from the two Purple connections on your Receiver (Labled "PRE OUT SUBWOOFER") to the Red and White connectors on the back of your Sub (it does not matter which Purple connecter you plug into either the Red and White)
Set the volume control on the Sub to about 75%, and keep the power switch in the "ON AUTO" position. To set the Low Pass value, look at the back of one of the front speakers in your setup, and note its frequency range (will look something like 100Hz - 17kHz). Set the Low Pass at a value slightly higher than the low value on the back of your surround speakers.
To set the phase switch, stand in the middle of the room with some music on (something with some bass, but not over the top bass) and have someone switch between 0 Deg and 180 Deg. Listen for which setting sounds "Louder and Fuller". This is the one you want. You will need to do this each time you move the Sub, as its position may change its phase in relation to the rest of your system.
Good Luck!
Posted on Mar 26, 2010
Can I add Polk Audio PSW10 10" Powered Subwoofer, 35Hz-200Hz, 50W Continuous Power, Single with my Yamaha ATS-1050 Sound bar?
Yes. Connect a standard rca cable from the audio out jack of your yamaha to the input of the Polk sub.
Aug 18, 2016 | Yamaha Audio Players & Recorders
Where is the fuse in Polk psw 10 subwoofer?
You will have to remove the plate amp and look on the pcb, it is generally located near where the main power lines come in.
If you still can' find it contact Polk tech support, Ive owned several Polk products and always found there tech support very helpful; very helpful;
Tech/Product Support
9AM-5:30PM EST Mon-Fri
1-800-377-POLK (7655) Option 1
FAX: (410) 764-5470
polkcs@polkaudio.com
International: +1-410-358-3600
Nov 23, 2014 | Polk Audio PSW Series PSW10 Black 10-inch...
What could be the issue with my sub woofer power?
Many of these SUB amps ended up with Capacitor failures in the Power supply section . Find someone who works on amps or TVs to have a look see.
May 26, 2014 | Polk Audio Polk DSW PRO 550WI Subwoofer
Subwoofer set up polk audio 6750
Connect the subwoofer to an amplifier/audio receiver with the proper cables. Reply back with your setup so I can get some more information.
Dec 25, 2011 | Polk Audio Audio Players & Recorders
My polk psw404 has no power, I check the fuse at power source
Could be the power supply but the transformer may
have opened up due to a "surge". Might have to contact Polk to see whats up and/or dealer as the
amp may need sent in for repair!
May 24, 2010 | Polk Audio PSW404 Subwoofer
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
No sound comes out of the subwoofer. Sound passes through and the power light is on, but no subwoofer sound. Any ideas? Fuse? Easy fix? Can this subwoofer be replaced? is it still available? Can I buy a...
this may be a dumb question but have you turned up the signal. there should be a dial on the back that you can turn the power up. power light on, signal passing threw, the only other thing it can be is the built in amp itself may be dead.
Aug 02, 2009 | Polk Audio PSW50 Subwoofer
Subwoofer was working okay and now I have a subwoofer err - no sound
CHECK THE WOOFER SETTINGS FROM THE MAIN MENU. AND CHECK THE WIRE CONNECTED TO UNIT. CHANGE THE WIRE, IF STILL NO SOUND, GET IT REPAIRED TO YOUR AUTHORISED PERSONNAL.
Apr 24, 2009 | Polk Audio PSW10 Subwoofer
Polk Audio PSW202
The power supply or amplifier has a shorted component.
Nov 08, 2008 | Polk Audio PSW250 Subwoofer
Polk Audio PSW202 Subwoofer Logo
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
