Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Battery or ?
My Swivel Sweeper is less than a year old and is used once or twice a week in a small area. It stopped working and I called Swivel Sweeper, They said it had to be the battery. I purchased a new battery; charged it the appropriate amount of time and the sweeper still does not work. It is very clean. There is nothing caught in the brushes. It's just totally dead! Any ideas?
  • Anonymous Jan 26, 2009
    I was going to buy a new battery pack. Now I don't know if I should or not.
  • 294 Answers
If this model is under 1 year warranty, I would suggest that you take it to a warranty repair shop or that you ask for a replacement. with a Return Material Authorization (RMA) at no further cost to you for shipping.
Posted on Mar 01, 2009
Rough motor noise
How old is the sweeper? If it is 5-10 years old the motor is probably wearing out and would need it's bearings replaced. You can replace the whole sweeper for less.
Dec 29, 2013 | Dirt Devil Featherlite Bagless Vacuum...
Swivel sweeper brushes slow with full charge even after cleaning brushes
When you say you cleaned out brush's are you talking about the build up between the bristles? I've found that I have to take the roller completely off and use fine needle nose tweezers to actually get all the stray hairs and caked on dirt as it hides close to the inside of the brush rollers. It's a bit more work to do this but I think you might benefit from this extra step!
Good Luck!!!
Jan 23, 2013 | As Seen On TV Swivel Sweeper Vacuum
My swivel sweeper 2 caught a carpet string and stripped the small plastic gear on the motor. How can I get another gear so I can repair my sweeper? Thanks, Ivol...
We were able to find every part ofr the swival sweeper exact for the gears you are looking for.
You can get a new complete sweeper head for 19.99 at:
http://www.swivelsweepercatalogs.com/
Mar 06, 2011 | As Seen On TV Swivel Sweeper Vacuum
I bought a new battery charged it, and it starts then slows to a stop?
Possible that the drain of the mottor is exceeding the current requirement of the battery.
So check the battery for voltage and current according to the standard set, then check the vacuum motor to work from another source to determine the currrent factor to confirm if there is a mismatch or poor efficiency.
Sep 16, 2010 | As Seen On TV Swivel Sweeper Vacuum
Brushes don't turn, light works when switched on, battery fully charged
Hello. Generally, when the brushes don't turn you will find that the belt is broken. In some cases, also the brushes will stop if they are clogged up with animal hair, etc. Regards, Joe
Dec 14, 2009 | As Seen On TV Swivel Sweeper Vacuum
Can you take the Swivel Sweeper battery pack apart to replace the batteries with new rechargeable batteries? Batteries look like AA or AAA, but it appears that the battery pack is sealed. Is there any way...
Yes you can if you have a way to cut through the plastic outer case,(I used a Dremel rotary tool). Inside you will find six double A Ni-mh batteries. I found eight of these for sale on ebay for around ten bucks,then all you do is solder some wire to the batteries like the original battery pack and tape up the case and charge.
Nov 20, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Swivel sweeper stops running. I purchased a new charger and a new battery and the same thing happens.
Sometimes on the corless sweepers, the internal connection where you inster the charger on the vac will break or be bad. take it in for repair for an estimate.
Oct 11, 2009 | Hoover H3030 FloorMate SpinScrub 500...
I bought my Hoover...U5180-910...@ my local Wal-Mart. It is literally falling apart. The sweeper has NOT been abused. Yes, we have 2 cats & a dog but the problems I am having w/ it should not be...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=729453
Generic problem for all Vacuums
Posted by ldjezt on Jul 01, 2008
I bought my Hoover...U5180-910...@ my local Wal-Mart. It is literally falling apart. The sweeper has NOT been abused. Yes, we have 2 cats & a dog but the problems I am having w/ it should not be warranted. The handle has broken. The wheel/roller on the bottom of the machine has broken off & now it has just stopped working. I repeat, this vacuum has NOT been treated badly @ all. I can not be w/out a vacuum. Thank you for your help, hopefully. Debi
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best thing to do if the vacuum is less than a year old then take it to an authorized Hoover vacuum cleaner dealer and some parts and maybe not all might be warranted
The handle can be fixed and the wheel roller also can be fixed by any vacuum cleaner dealer. With pets the suggested belt change should be done every 3 to 4 months with 2 cats and a dog and the extra belts should be stored in a Ziploc bag in the refrigerator. If the vacuum just stopped working it could be the motor and if less than one year might be warranted. Feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Vacuums
Swivel sweeper battery is not charging
The battery is done for sure. take a look here Finally charging for our multi device world and choose the best one for you (by price and seller). cheers
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
251 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
