Question about Tools & Hardware - Others
I have a bosch 4" belt sander 90497 model 3. I understand that this was when they were with Stanely corp. I can not find brushes for it. Help! otherwise it works great.
5 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: toothed belt bosch 1274 dvs
If I am correct, when holding the tool in the normal operating position there should be an oblong cover on teh left hand side nea the back of the tool. It should be held on with a screw. remove this cover and you can access the belt . MAKE SURE THE TOOL IS UNPLUGGED. the belt should pull off/push on with a bit of force. Turning the pulleys as you put it on will help it go on evenly. If it is too stiff, put the belt in some boiling water for a minute or two to soften it up a bit.
Posted on Nov 04, 2008
  • 384 Answers
SOURCE: Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Posted on Jun 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Posted on Sep 12, 2009
agent91
  • 2100 Answers
SOURCE: I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
Posted on May 25, 2010
Testimonial: "Thank you for your help, now all I need to find is my manuel to break it down."
Tip
Replace drive belt Bosch pbs7a
To replace drive belt on Bosch 7 PBS belt sander remove cover, 3 screws, place new drive belt over splined drive pulley. Feed belt clockwise over paper pully and Utilize welded hexigonal with suitable wrench to turn and 'pop' the belt on.
on Feb 02, 2014 | Bosch Belt Sander Drive Belt For Pbs 7a,...
NEED A AUTO REPAIR SHOP TO RESET IT ONLY THERE COMPUTER CAN DO IT OK
Nov 14, 2012 | Bosch Belt Sander Drive Belt For Pbs 7a,...
My Bosch 1276 DVS belt sander abruptly stopped working. Could it be the switch?
that is possible, but was the tool operating properly first?? unplug tool and check the cord for any breaks, then what I would do is clean the tool as good as possible with compressed air and if you can remove the brush caps do so and check the condition of the spring and clean the area. DO NOT sand the brushes but look across the face to see if both look worn evenly. If you have a volt ohms meter check from the plug to the brush holder with the switch on brushes removed to see if you have continuity and if not then I would have to think the switch
Feb 11, 2011 | Bosch 1276DVS 4" x 24" Dustless Variable...
Belt sander
You're plugged in to a dead outlet, OR the rotor brushes are not in contact with the rotor, OR the power cord is partially severed,
Jan 06, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
My Bosch 1274DVS 3" x 21" belt sander will run only sporatically
Hi
Definately sounds like bad switch or contact to the switch
Feb 26, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
CLEANING SANDER BUSHINGS
It's usually not the brushes but the commutator that needs cleaned. The commutator is the surface the brushes ride on. Go to Walgreens and buy a multi-surface nail file, one of the soft ones that are about 3/4" square with different colors for different grits. Don't start at the coarse grit!! Start at the medium grit and lightly drag it over each section in a smooth arcing motion, when the commutator surface is shiny it's clean, then replace the brushes with new ones.
Feb 16, 2009 | Bosch Power Tools Sanders Orbital Sanders
Toothed belt bosch 1274 dvs
Nov 03, 2008 | Bosch 1274DVS 3" x 21" Belt Sander
Tools & Hardware - Others Logo
50 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
