Question about AT&T 1040 4-Line Corded Phone
When i pick up the receiver on at&t 1040 i get three beeps and no line light
I can't chat on face book..
ја могу само на опера бровсер да да видим основне графице а на друге бровсере немогу а сада на опера немогу да видим ко је све на чату и то ми се догађа од ових недељу дана и све исто .........................................................СКО ЈЕ ТО НЕШТО ДО ВАШ МОЛИВАШ ПОПРАВИТЕ ТО АКО ЈЕ ДО МЕНЕ ПОШАЉИТЕ Е МАИЛ СА ПОРУКОМ ШТА ТРЕБА ДА УРАДИМ НА ЕМАИЛ АНДРЕСУ -анђео_беч@хотмаил.com
Jun 21, 2011 | Facebook Social Network
Ever since i brought my HP 1040 fax machine i can
it may possible that you have a DSL conn. for internet & phone line.
In DSL conn. we need a DSL filter to be fitted in ur DSL line,so that you can get a analog line for fax/voice calls.
And if you have a VOIP conn. then plz contact HP technical support.
Nov 20, 2009 | HP 1040 Plain Paper Inkjet Fax
Unable to receive fax without picking up hand set - any pointers? We have the setting to Auto
CHECK THE CABLE IS IN THE CORRECT SOCKET AT THE BACK THE CABLE NEEDS TO BE PUT IN THE LINE SOCKET NOT THE TEL SOCKET AND ALSO MAKE SURE THE RX OR RECEIVE MODE IS SET TO FAX MODE IF IT IS JUST A FAX LINE OR TEL FAX MODE FOR USE WITH PHONE.. THE TROUBLE IS USUALY WHEN YOU ARE USING THE FAX ON A LINE USED FOR TEL USE AS WELL..__
Aug 05, 2009 | HP 1040 Plain Paper Inkjet Fax
Fax is not Receiving
Unplug the power cord for 10 seconds.
Do you have DSL or any other kind of digital phone service?
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Machine does not receive faxes
It the funky line DSL?
Fax machines are designed to be on a dedicated ANALOG phone line. Sorry
Beeping
No dial tone detected.
Sep 19, 2008 | HP 1040 Plain Paper Inkjet Fax
HP 1040 "JUNK " FAX MACHINE
can hp 1040 fax transfer printed copies to hp pavillion note pad
eadyj1948@yahoo.com
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Won't receive fax
Reset RING DELAY so that machine picks up on 1st ring, and does not disconnect before fax can be sent to you.
Jan 07, 2008 | HP 1040 Plain Paper Inkjet Fax
Hp 1040 random problems
1-the line itself could be bad ( not the jack where you nplug in the wall) the cord itself could have a break in it. try changing the cord cost $1.00 at a dollar store
2-if the memory is full after receiving a lot of faxes, check the memory when it happens
3-if the toner is low it will store it in memory, by you checking the machine turning off and on removing toner etc... you end up resetting it for awhile.
Dec 13, 2007 | HP 1040 Plain Paper Inkjet Fax
AT&T 1040 4-Line Corded Phone Logo
94 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
