Question about Samsung Televison & Video
Overheating on a samsung plasma tv
Tv shuts down after 2 hours
Tv shuts off
http://www.retrevo.com/s/Samsung-SPN4235-TVs-review-manual/id/275bh940/t/1-2/
www.scribd.com/doc/.../LG-TV-Plasma-Training-Manual
http://forum.electromaniacs.com/topic/6146-samsung-samsung-plasma-training-manual-ppt-zip/
Please find service manual and a user manual above. You most likely have a switchmode power supply problem, the PSU, is shutting down, for safety reasons, due to a fault, that may cause a fire and explosion or both. use these manuals to isolate your problem
May 23, 2010 | Samsung SPN4235 42 in. Plasma HDTV
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
Oct 27, 2009 | Samsung HP-R4262 42 in. Plasma Television
Our Panasonic Viera 46
Seems like a hardware problem. Something is probably overheating or something like that.
I would suggest either returning/exchanging the TV (2 wks is usually in most return policies) or if you can't do that, register your TV with panasonic. After registering, call them up for service covered by your 1 yr warranty.
Aug 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
TV SHUT S ITS SELF OFF
Is the unit free of dust and debris from dust? If its overheating there are may factors that play in this
1. fan spinning but not enought RPM rotations per min ( not fast enough)
2. room temp
3. dust
other then that some capictors must have exploded inside withc will cause a overheat.
Apr 22, 2009 | Samsung HLR5064W DLP Projection TV
TV shuts off after 1/2 hour
sound like a heating problem and best and easy way to fix that would be to blow out the dust in it, but if it a Power board problem you should have it sent to a tv repair shop. check the dust problem first.
Jan 07, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Samsung TXM2796HF Turns off after 45 min to 1 hr
Probably some component in the power supply. Look for a leaking or swollen capacitor. They can change value during operation unlike a diode or transistor that either works or does not work. U might even remove and test all caps in the PS area and replace any one that is questionable regarding its specs.
Aug 30, 2017 | Samsung TXM2796HF 27" TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
My Samsung Plasma just got burned in!
I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
35 people viewed this question
Jerry Greenberg
Jerry Greenberg
