1992 Mitsubishi Pajero Logo
kama kelly Posted on Nov 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On the dash of my 92 pajero the two front wheels keep flashing green when its not in 4x4 how ever i degreased under the engine and gearbox and realised after.that the lights had stop flashing until my son moved the shift out of 2h once i put it back they started flashing again what could it be ? all the 4x4 works fine.
raj somaiya
Level 3:
  • Mitsubishi Master 5,370 Answers
  • Posted on Nov 29, 2012
raj somaiya
Mitsubishi Master
Level 3:
Answers
5370
Questions
0
Helped
3570973
Points
14579
4X4
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 16, 2011
SOURCE: I have a 1998 glx
It depends on how long it flashes for, when you select 2wd try and drive for a bit at slow speed and the light should stop. This is normal. If it is still flashing when you are driving then it may not be changing correctly, this could be a number of things but I would recommend you get a pro to check it out as the transfer case is very expensive to replace.
Anonymous
  • 147 Answers
  • Posted on Mar 29, 2009
SOURCE: 1999 Mitsuishi Montero sport 2H shift light flashing
Bad 4wd position sensor located on transfer case or bad sensor located on right front axle housing for 4wd engagement position.
Anonymous
  • Posted on Jan 26, 2010
SOURCE: when i put my mitsubishi pajero into 4X4 and make a full turn
were you on hard ground when you tried turning on 99 % of your 4x4 your wheels have to be in very loose dirt ,sand. snow. mud when turning sharp if you were on a hard surface the sound was your front axle trying leave your 4x4 but if you were not look at your transmission mount and motor mounts i actually sheered off my tranny mount trying to crawl sharply over large rock i was in dakota my truck engine attached to front axle axle turns motor shifted trans mount broke
Testimonial: "Thanks man, this was helpful. I tried it on sandy surface it worked like a breeze :)"
Anonymous
  • Posted on Apr 28, 2010
SOURCE: why are the four wheel dash light on in my
shift the 4wd shift to the disengaged position. If the lights still stay on the 4WD may be sticking. when i engage my 4WD if i stop the vehicle immediaetly after the lights will stay on when I switch on the ignition next time. however on starting and moving off after a few seconds they come off.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Apr 24, 2012
SOURCE: my pajero won't engage or disengage from 4wd and the light in the dash keeps flashing
You need to have the system scanned for fault codes.
2answers
How do i get out of 4x4 on a 2000 jeep grand cherokee laredo
Thanks.
I need a wiring diagram for a 1993 Dodge 2500 series 4 wheel drive truck
Thanks.
I have a 1999 dodge sport 1500 4x4 and it makes a clunking sound like it is skipping gears when I engage it in four wheel drive at times. I checked all fluids and changed them and checked u-joints and all...
4X4
Thanks.
1helpful
Stuck in 4 wheel lo, how do i get it back to 2 wheel hi ?
Thanks.
2answers
What is a 4 wheel drive switch
Depending on the make and model, it could be the control switch on the dash or the switch that moves the gears in the transfer case.
How to set the 4x4 electronic selector switch on a jimmy 2002
4X4
Thanks.
4x4 will not engage on 2005 tahoe
It can be faulty 4x4 wd switch.
4X4
Thanks.
Will not shift into 4wheel drive
On these issue,there are few solved help links for troubleshooting the issue easily.-------
Click the link below:---
4x4 will not engage on Ford F150? http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing 4X4 LOW LIGHT IS FLASHING ON DASH
Thanks.
I have a 1998 explorer and the 4wheel drive will switch on like it should and the lights do not blink or anything but I can tell the rear end doea lock in low but never any power to front axle in any...
Thanks.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
