Question about Dryers
How to remove the back of a kenmore 11063942101
3 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: kenmore elite about 6 years old and doesn't get things dry
fix exaust hose
Posted on Feb 18, 2009
  • 113 Answers
SOURCE: Getting the heating element casing back on to the back of a Kenmore elite dryer Model#11063942101
there are slots in the casing that slide down on tabs comeing out of the dryer. put the top part of the casing in then put the bottom part in and slide down on the tabs
Posted on Apr 23, 2009
When was Kenmore dryer model number 11063942101 made?
The following link will take you to a website where you can type in your information and it will give you a time frame of when your dryer may have been made. You will also need your serial number as well.
Oct 16, 2014 | Kenmore 63942 Dryer
I have a Kenmore Dryer Model 11063942101. When I press the start button the dryer starts but stops as soon as I release the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2011 | Kenmore 63942 Dryer
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
Kenmore elite dryer 11063942101 works if I force the switch to stay in the on position but won't start by just pressing the switch. Replaced pust-to-start switch. Same problem. Vacuuming out the areas...
The problem is definitely not the motor but rather the motor relay or the electronic control. Either the motor relay is not working to close the motor circuit or the electronic control is not powering up the motor relay to serve its function.
The motor relay and the heater relay are identical and can be used interchangeably. The heater relay may be used in place of the motor relay if the dryer heats up when the start switch is held on. It indicates that the heater relay is working.
Disconnect power to the dryer then pull the end cap trims off then remove the control panel securing screws. Once the screws are removed, rotate the control panel up to the rear of the dryer.
Disconnect the wires and remove the relays then put each in the place of the other. Refer to the component layout diagram for the location of the relays.
Reconnect the wires then rotate the control panel down back into position then plug the dryer in and start it. The dryer should start and continue to run when the start switch is released since the working heater relay is used but will not heat up indicating that the motor relay is not working. Otherwise the fault is in the electronic control.
Replace the faulty component and it should address the problem. The relay (heater/motor) is part number
3405281 and the electronic control is part number W10116565.
Squeeze on the electronic control mounting bracket as shown then pull the board up to remove.
Insert the new control board and gently press it down into position. Transfer the wires from the old board to the new board one at a time.
Simply unscrew the relay to be replaced then secure the new one into position and transfer the wires.
Rotate the control panel down and secure it back into position to complete the repair.
Aug 30, 2010 | Dryers
Apr 23, 2009 | Dryers
How do you remove the back of a kenmore electric
http://www.partstap.com/ please go to this site and look for full diagram thank you for useing fixya please rate me
Feb 25, 2009 | Kenmore 63942 Dryer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Drum Spins - NO HEAT (110.63942101)
Try replacing the heating element. This should solve your heating problem. Sign, Spurs21
Jun 12, 2007 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
