Question about Lexmark E260 Laser Printer
Lexmark 260dn dirty black mark on left side of page
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Posted on Jun 04, 2009
  • 1684 Answers
SOURCE: Printer making marks down the left hand side of every page
hello,
This sounds like the photoconductor units for both black and blue need to e replaced. Open the front of the printer like you are changing toner cartridges. On the front door parts that opens to you there will e four pieces, 1 for each color. Look at the one with blue on it and the one with black and look on the ends of these, they are the photoconductor units. I bet both of the colors have worn sections compared tothe magenta and yellow ones. The replacement part number is C53030X and you will need 2 of these. They have a life span just like toner and have to be replaced too.
I hope this helps,
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Testimonial: "Spot on... solved the problem"
  • 150 Answers
SOURCE: Black marks on the side of page
You are right the drum needs to be replaced. the coating wears down and starts making marks I sell them for 55.00 complete or just the drum for 22.00 It's easy to install a new drum with a screw driver and a pair of needle nose pliers. steven 818-888-0006
Posted on Mar 10, 2010
My lexmark x544 gets a black line down the page when i put it in the tray feeder. What do I do?
Is the black mark in the same place on all print outs? If so, it could be that the paper feed rolls may be dirty.
Oct 16, 2014 | Lexmark X544dn All-In-One Laser Printer
I have lexmarks 260dn printer .it's DHCP is off .how to on it. plz help
This procedure requires that the printer to be communicating on the network. A temporary IP address may have to be set on the device to perform this procedure. If further assistance is needed, please contact Lexmark Technical Support.
1. Open the printer's web page or embedded web server.
2. Click on Configuration or Settings.
3. Click on the Network/Ports.
4. Click on TCP/IP.
5. Place on checkmark next to Enable DHCP.
6. Place a checkmark next to Enable AutoIP.
7. Scroll down to the bottom of the page and click Submit.
Jul 06, 2011 | Lexmark E260dn Laser Printer
I have a X4270 fax machine. Whenever i send a fax the recipient says there is a black line running down the left side of the page. I changed ink cartridges but it did not help. Can it be fixed?
The X4270 has a pretty straightforward scan path. If you follow the instuctions on this link, you'll find that you can clean the white roller and scan lens with a lint free cloth and water. It will get rid of the mark....unless you've managed to do something ugly like run a staple through the machine (I did that on a laser and scored the drum....that sucked).
Carl
http://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.htmlhttp://www.lexmark.com/publications/pdfs/2007/4200/ug/en/frameset.html
Feb 18, 2011 | Lexmark Office Equipment & Supplies
3 BLACK MARKS ON EACH PAGE ON RIGHT SIDE-HAVE CHANGED CARTRIDGE AND WIPED ROLLER
Remove the toner cartridge from the MFP and gently shake it back and forth five or six times. Then place it back in the printer. Print a test page.
If you have an extra cartridge try to replace the cartridge toner.
If you need further assistance, please contact Lexmark Technical Support Center.
Feb 01, 2011 | Lexmark X342n All-In-One Laser Printer
Mar 10, 2010 | Lexmark E250dn Laser Printer
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
hello,
I hope this helps,
Buddy
Corporate Computer
Jun 18, 2009 | Lexmark E232 Laser Printer
Jun 04, 2009 | Lexmark E232 Laser Printer
3-INCH WIDE VERTICAL LINES RUND DOWN LEFT SIDE OF FAX MACHINE
Do your incoming faxes have the same marks?
If not you might find that the scanning part of your machine has a dirty mark on the glass or that the unit has become faulty.
Try and take a copy from the machine and print from a report or any print from memory.
If you have the black lines on both then i'd suggest getting a new drum unit, if u have it only on the copy I would have a look at your scanner glass and see if there is a dirty mark on it. if not maybe call out an engineer as the scanner unit maybe faulty.
Need anymore help msg me.
Dec 11, 2008 | Office Equipment & Supplies
Lexmark t522 black marks on leftside of pages
the top roller is the charge roller and the bottom one is the transfer roller if a foriegn substance got on either roller they could create this problem the oil from your fingers getting on them could create this. given everything youve changed the rollers are whats left. you can clean the charge roller but its better to get new ones these are consumable
Apr 22, 2008 | Lexmark T522 Laser Printer
Lexmark E260 Laser Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
