Question about Toshiba E-STUDIO 650 Copier
I have a Toshiba E-studio 650 with a C46 error code.
When the copier comes on and is warmed it goes to straight to call an repair person. I was told that there was a clank sound then stopped working. Now giving a C46 error.
  • mselders Jan 16, 2009
    Hello
    I tried what you told me to do. The call a repairman screen doesn't come up now, but now I have a roller continuesly turning. It's louder than normal. Could you explain what happened when I, Turn power off , press and hold down 0 and 8 while turn on the power, enter 400, press start,enter 3 ,press start, enter 0 press set or interupty. turn power off and back on again.
    Oh when I entered the 3, (there are two columns. 0's in each column. 3 is entered into the right column, then press start. Next, enter 0, it comes uo next to the 3, showing 30, set is on the LCD screen, I pressed the interupty button. turned off he machine, then on, comes up normal, sounds like the fuser roller is continusely turning so I turn it off,
    Is this the result we are looking for?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
I have a toshiba estudio code CE50 please give a solution
Posted on Jul 14, 2013
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; The error code you post out it's means "fuser pressure roller thermistor bad let's try to reset if don't work have to replace it;
Posted on Jan 10, 2009
How to reset Toshiba e studio 207 photo copier c46 error
e studio 207 model only have c41 to c45. there is no c46 error cord.
May 03, 2016 | Toshiba Office Equipment & Supplies
Download printer driver
toshiba estuido 600 giving error c260
Jul 03, 2013 | Toshiba E-STUDIO 650 Copier
Error code CF70 on toshiba e-studio 600
toshiba e studio600 error codes cf 70
Jul 20, 2012 | Toshiba E-STUDIO 650 Copier
Hello, I turn on my Toshiba E-Studio 166 Photocopy Machine and it shows an Error Code C 41, please how can I fix this problem?
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Jan 26, 2011 | Toshiba e-Studio163 Copier
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
What is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Dec 20, 2008 | Toshiba E-STUDIO 650 Copier
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
Problem while starting
You need to press the clear and the eight button. You will then see the error code. Let me know the error code and I may be able to help more. http://www.tonerovernight.com
Apr 04, 2007 | Toshiba E-STUDIO 650 Copier
427 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
