Question about Refrigerators
Kenmore 51564101 does not make ice
Water supply providing water to water dispenser but not refilling ice tray. ice tray teeth are rotating. Have reduced cold temperature of freezer to see if the line was frozen. also have changed filter after problem occurred
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Nov 28, 2012
  • Erich Bleiweiss Nov 29, 2012
    kenmore coldspot 10551564101
  • 55 Answers
SOURCE: ice maker
Check if you can increase the ice cycle
Posted on Nov 18, 2007
  • 146 Answers
SOURCE: Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
Posted on Dec 19, 2007
SOURCE: Kenmore - Ice Maker Not making much ice
check water inlet valve on your frig
Posted on Jan 17, 2008
TheMobilian
  • 8220 Answers
SOURCE: ice maker stopped working. water dispenser works,
Your water valve has a dual solenoid set on it. You ice make solenoid is probaly gone bad.
Posted on Jun 09, 2009
SOURCE: I have a Kenmore side-by-side, model 253 54364405.
washerwill not spin
Posted on Feb 18, 2010
No crushed or cubed ice being produced
Ice tray may not be filling. Have a look under or on the side of the icemaker., Some have a little button to reset it. Press and hold the button in and see if the ice tray rotates and refills with water.
Nov 20, 2016 | Refrigerators
My icemaker will not dispense ice. The tray is full, but won't rotate to drop cubes.
Ice sitting for a long time in the tray sometimes freezes the mechanism. Try unloading the tray of ice. Make sure nothing is jamming the parts that dispense the ice. Wait for new ice to be made and see if it works.
May 19, 2016 | Kenmore Refrigerators
Amana Fridge isn't filling the ice tray with water...=/
it seems to me (no expert) that you have an ice buildup in the tubing to the freezing portion of that unit. I can only suggest to turn off the Refrigerator for a little while, an hour or two at most, and see if the tubing thaws.
Aug 30, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
Water dispenser works, but ice maker not working.
i have the same problem right now.. water supply is goodand water dispenses from dispenser. tray that makes cubes not getting any water. looking for help also.
Dec 27, 2008 | Kenmore 53642 / 53644 Side by Side...
ICE MAKING NOT WORKING ON MY KENMORE SIDE BY SIDE
Hello Heavensentme..
Since you pointed out that you don't have a restriction that limits water flow to your fridge.. then you may have a bad inlet valve that allows that same water to refill the ice tray or.. the switch that senses the ice bin is full is stopping ice from being produced.. The motor that rotates the ice tray may also be defective.. .. If possible,, can you empty your freezer compartment and let it thaw out and then try a fresh start so that you know you don't have any ice build up that is stopping the ice tray motor from rotating or the inlet for water isn't frozen? Otherwise.. they aren't that complicated but you kinda have to know what to look for and what to not touch in order to repair them.. Not sure this helped or not but hope so,,,
Regards
Rick
Nov 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
Nov 06, 2007 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
