How to connect brother printer Mfc-9840cdw to my computer network wirelessly.
  • 3,606 Answers
Hello you can download the software here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc9840cdw_all
Please select your windows system 32 or 64 bit.
And download the software.
Uninstall all the old software before you install the new.
Download also a manual:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc9840cdw_all&dlid=&flang=English&type2=-1
This file is in the pdf format so you need adobe reader.
To connect it wireless you need a extra module on the pc to communicate with the printer it`s probably a bluetooth module.
I think it wil be easyer to connect it with the lan cable or usb.
If you have a router connect the lan cable to one of the 4 ports on it.
Or buy a switch to connect betveen the pc and the printer.
Good luck
Posted on Nov 30, 2012
SOURCE: black dots on print outs from Brother Laser Printer MFC-9840CDW
meaning your printer drum is growing weak and will soon need to replace
Posted on May 23, 2009
SOURCE: Brother MFC-7840w wireless printer won't connect to network
Ignore the instructions that come with the printer, choose Open System, then choose WEP, enter, and it hooks up. Thanks to the above posters for this solution.
Posted on Oct 18, 2009
Jimsta01
  • 405 Answers
SOURCE: Brother MFC-8460N network printing, local scanning
Yes this is possible. Depending on the type of installation that has been done on the computer, you can even scan documents to your computer as a network scanner.
You can check and see if all the features have been installed on your computer. Click on start, all programs, and look for the folder called brother. If you can find brother you can look for the sub category for Conrtrol Center. From Control Center you can scan by clicking on one of the icons. Like file or image.
If none of this is installed, get your installation disk and install the software, you can do a network installation or a Local (USB) installation.
If you decide to do a Local installtion remember to only plug in the USB cable when promted to.
If you decide to do a network installation, the machine should already be installed on the network, which I assume it is since its being used as a network Printer.
Please let me know if any of this info was usefull, and if you require more info about this.
Posted on Apr 12, 2010
SOURCE: MFC-9840CDW Laser Printer: I have a Brother MFC-9840CDW laser printer it is o...
Wipe the paper feed rollers with a clean rag wetted with plain water. You can also replace the feed rollers, search for "paper feeding kit" for this printer. Should be $20 to $30.
Posted on Aug 05, 2010
  • 3 Answers
SOURCE: Wireless printer problem
Brother has posted a Network Connection Repair Tool on their site under downloads. Worked great to put my MFC printer back on line with my network.
Posted on Mar 13, 2011
Text missing when document is printed from Brother MFC-9840CWD
Hello,This issue may becaused by poor connection. Check to see if all interface connection cables arein the printer. If the printer doesn't establish good connection with thecomputer print quality will decrease.Second thing you can check are thesettings on the computer. Are they matching with settings in Brother MFC-9840CWD.This is issue is not caused from the toner cartridge or drum unit.
May 09, 2012 | Brother MFC-9840CDW Laser Printer
Problem with Brother MFC-9840CWD
Hi,Check to see in the connectioncables are all plugged in correctly.Open the printer and see if drumunit and toner cartridges are installed correctly. Sometimes not well installedconsumables are the cause of that particular problem.See if the print driver on yourcomputer is correctly installed. Try and reinstall the driver.Check if your printer is working in onlinemode. Sometimes printer changes online to offline method. If printer is atoffline mode click Start button on your computer, enter Control Panel. Click onHardware and Sound and choose Printers. Right click on Brother MFC-9840CWD andmake sure that the Use Printer offline is not checked.Hope this helps.
Netwok printing problem
TRY TO SHARE THE COMPUTER THAT IS CONNECTED WITH THE PRINTER SO THAT EVERYBODY CAN VIEW THAT PRINTER AND THEY CAN ADD IT TO THEIR COMPUTER BY ADDING THE PRINTER AS NETWORK PRINTER.
Feb 03, 2011 | Brother MFC-9840CDW Laser Printer
May 18, 2010 | Brother MFC-9840CDW Laser Printer
MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
May 17, 2010 | Brother MFC-8870dw Wireless Multifunction...
Mar 28, 2010 | Brother MFC 7840W Printer
Brother MFC 9840CDW
Sometimes just a static shock can do that, you need to replace the control panel pcb to fix it.
Dec 24, 2009 | Brother MFC-9840CDW Laser Printer
Brother MFC-9840CDW Wireless printing on Vista
maybe is not configured to work with vista;s sorry.
Mar 19, 2009 | Brother MFC-9840CDW Laser Printer
417 people viewed this question
jasbo
jasbo
