Question about Compaq Keyboard
I need to replace the keyboard on a compaq c300
I can't seem to get the bottom cover off. It looks like there are screws coming from the top that I cannot find... Can you help?
  • kajuana Apr 23, 2009
    i have the same problem and the hp website does not work to view the manual
This just happened to me with a black Compaq keyboard. There are two additional screws hidden under the rubber pads. You'll have to remove the pads (use a screwdriver or your nails) to get access to those screws, and then when you're done put the pads back in place (they are sticky on the inside, so I guess they'll glue back to the keyboard and not fall).
Posted on May 04, 2009
    Master:
  • 461 Answers
As per the service manual available here on the HP Website is only necessary to remove the switch cover to access the keyboard screws. The switch cover is secured by to screws located in the battery compartment. The keyboard screws are located on the top of the system under the switch cover.
Posted on Jan 10, 2009
I have a hp-compaq presario c300 and i forgot my power- on password. i need help! or need backdoor password in order to fix. please!
NEVER install a power on password without making a note somewhere as to that password is - there is no fix appart from replace the m/board as the POPW is within the cmos chipset - there is a rest button on the m/board but I do not think it will clear this problem. It is located under the top cover just below the mouse input port - requires removing the top cover - screen keyboard ect.
Jun 16, 2010 | Compaq Presario Notebook
How to replace/upgrade RAM on HP/Compaq nx5000 laptop? HP's quick reference guide says the slots are under the keyboard deck? How do I get there? Thanks
to remove the keyboard u will 1st need to undo the screws that hold it to the board should be the 2 or poss 4 directly unde the corners of keyboard other than that the covering panel at top of laptop will need removed 1 screw either side underneath screen hinges and poss few small 1s where battery slots in once cover removed the keyboard will be held on with 2 screws at top and the cable remove both and viola
Jan 16, 2010 | HP Compaq nx5000 Notebook
How do you get underneath the keyboard
You don't need to remove the keyboard to access the ram. Just undo the single crosshead screw on the removable cover in the middle of the laptop from beneath. I you do ever need to remove the keyboard there are 2 screws underneath this cover, which are marked with a keyboard symbol. Undo these and then slide the 4 small lugs at the top of the keyboard and it will lift up
Jan 04, 2010 | HP Compaq nx6325 Notebook
Compaq 2200 pc plug replacement diy
Hi there.
With all HP laptops the keyboard screws should be clearly marked, look close under the laptop for 2 icons that look like a keyboard, that should be them, just unscrew them and the keyboard should come away.
Good luck and thanks for using FixYa!!
Apr 03, 2009 | HP Compaq Presario 2200 Notebook
HP Compaq nx9010 CD drive replacement
You are correct.
The screws for the dvd drive is under the keyboard.
there should be 2 tabs one above the f4 and the other above f12 take a regular head screw driver put it where those tabs are and gently pull down towards the touchpad and the keyboard should come up easily.
Now under that keyboard in the center you will see a opening and inside that opening you will see 1 philip head screw remove that by turning counter clockwise.
Right below where you removed that screw you will see another opening which has another philps head screw in it.
Remove that screw counter clockwise and the dvd rom should pull straight out with ease.
To put it back together just reverse the steps.
If you need further assistance do not hesitate to ask.
Dec 03, 2008 | HP Compaq Business Notebook NX9010
Need to remove my keyboard on Compaq Presario C501nr.
Remove battery.  Notice 5 phillips head screws labeled M2.5X4.  Of the 5, 2 have arrows pointing to them.  These 2 screws hold down the cover plate above the top of the keyboard, the one that has the 5 buttons for (left to right) WiFi, Power, Vol down, Vol up, and Mute.  Carefully pry up the cover after the 2 previously mentioned screws are removed.  You will see 4 screws at the top of the keyboard.  Remove these screws and gently lift up and slide up the keyboard.  Once the tabs at the bottom of the keyboard are clear, look to where the ribbon cable from the keyboard attaches to the socket on the motherboard.  Gently slide the very small tabs on the socket outward.  They only move about 1/16".  The ribbon cable should be free and you should be able to remove the keyboard assembly completely.
Install new keyboard in reverse order
Nov 29, 2008 | Microsoft Compaq Presario C501nr Notebook
Compaq Presario 1247 PC Notebook Keyboard Replacement
I don't think any screws come out of that laptop to get the keyboard out. Look at the very top edge of the keyboard for some release tabs, they are small, to release the keyboard.
Oct 30, 2008 | Compaq Presario 1247 Notebook
How to replace the Keyboard?
if you are not sound on technical ground its better to be done by the technician
Oct 17, 2008 | HP Compaq 6910p Notebook
Compaq Presario C300 Screen Hinges
you will find small end rubber ( round flat) that is on the top 4 pcs and the bottom 2 pcs, remove this and keep this for a while, then remove the screws that goes along w it.
from there you can find out how to remove the LCD
hope this helps
Aug 01, 2008 | Compaq Presario M2000 Notebook
How to disassemble a pantech c300
I used a micro screw driver set that can be purchased at Home Depot. There are two hidden screws: one on the top piece where the display is and one on the bottom piece where the keyboard is. The hidden screw on the top piece is under a silver rubber circle at center bottom of piece. The hidden screw on the bottom piece is under a silver rubber water drop shape located by the antena. These rubber covers can be removed by wedging them out with a mirco flat screw driver or pin.
Good luck...
Jul 10, 2007 | Pantech C300 Cellular Phone
Compaq Keyboard Logo
727 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
