Question about Sony Cybershot DSC-T200 Digital Camera
Display is foggy
When taking a picture, the view of the image is foggy. The camera had gotten wet a couple of years ago, but has since dried, and all else seems to work fine. Is this a smugged lense?
SOURCE: DSC-T1 Lense malfuntion
sounds like you have a ccd problem (imaging chip)
Posted on Aug 29, 2006
Bogdan
  • 198 Answers
SOURCE: Purple lcd display
Hello tonyj111, If your old pictures look fine on the display, then the problem is related to the ccd sensor itself. The purple color is displayed because of a problem in the signal transmision from the ccd sensor to the camera's main processor. This is done using 3 channels one for each primary color (RGB red green blue). If the connector to the sensor is broken, or got out of place (loose) because some mechanic shock or symilar, the data processing woun't come out right. It is purple because your camera's processor mess up blue and red signals therefore resulting same purple instead of blue or red colours. In order to fix this you will need to either send the camera to a service center to have those connections checked (if your camera is still in warranty you will want to do this) or ask me for further instructions if you wish to try to dissasemble the camera yourself. In either way the problem is fixable and in most probabilities a cheap fix will work. Good luck
Posted on Jun 04, 2007
jbreth
  • 69 Answers
SOURCE: E:91:01
According to the user manual an error 91 means that the camera has malfunctioned. You need to reset the camera. Here is how you do that:
Posted on Aug 26, 2007
  • 36 Answers
SOURCE: Blurry, streaked picture through view finder
Good Day, is the blurry picture pinkish in color? It might be an imager(CCD) problem, you can check it at sony support website, if it qualifies, just read the provisions, I will not comment on the policy, maybe it differ from country to country, i'm here in the philippines. thanks
Posted on Sep 04, 2007
SOURCE: sony camera turning itself off...
Are you using the sony charger. I found that the batteries were not charging properly on mine. Don't forget that the rechargable batteries reduce in efficiency the more times you charge them. Read this somewhere !
Posted on Jul 31, 2008
My SD800IS was working fine while in the very hot/humid environment of Yap. I took it out of my air conditioned room and went to take a picture almost immediately. The view finder, the LCD image and the...
The foggy images and lens was due to condensation caused by the camera's surfaces being cold in a humid/moist environment. Usually this happens and goes away without issue. If you believe issues are continuing, consider placing the camera completely in a bowl of uncooked rice. The rice should help eliminate the moisture in the camera.
Hope this helps.
May 06, 2011 | Canon Cameras
D80-viewer and display stay black, the flash
If your camera got moisture inside and you turned it on before it had a chance to completely dry (usually takes several days) you may have caused a short circuit.
Dec 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Help with my Fe-340 Olympus Camera?
I have olympus digital camera. from some time when I take photograph THe screen remains black & if the picture is shoot ,it is also black
Jun 26, 2009 | Olympus FE-340 Digital Camera
My Canon PowerShot A80 has a metering problem I think
Your Canon A80 has problem of defective CCD Imager Sensor and this part need to be replaced.
Good news is that Canon will replace CCD Imager free of cost as per announced free of cost repair scheme.
Click on Canon CCD Advisory for details how to obtain free repair facility.
Good Luck.
Nov 06, 2008 | Canon PowerShot A80 Digital Camera
Blurring on one side - Viewing and photo
A friend managed to find a very easy solution to this problem...the lens was dirty due to a 6 year olds sticky fingers...so I just needed to clean it.
Nov 06, 2008 | Sony Cyber-shot DSC-T10 Digital Camera
Image not visible on monitor screen
you need to install camera drivers and application software again.
Oct 22, 2008 | Casio QV-R41 Digital Camera
Canon A620 No Picture
First try hitting the DISP button (sorry if this offends, but many people have made this mistake). If this doesn't help, next try resetting the camera. Turn on the camera, and hold the menu button for at least five seconds. Believe reset is also in the menus.
If the above doesn't help, then unfortunately this sounds like your CCD image sensor may have failed. This would then require professional repair. Contact Canon at 1-800-OK-CANON.
Sep 14, 2008 | Canon PowerShot A410 Digital Camera
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
