Sound dropouts when the tv screen is mostly white.
When the TV programming has a mainly white or black screen the sound drops out. I added a second antenna thinking I needed a stronger signal, but It didn't help. The picture quality is perfect, with no visual noise or defects.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Need to know brand and model to help and also if a box is being used for signal or not- a box can cause this.
Posted on Dec 22, 2012
  • S Green Dec 22, 2012
    Panasonic TC-32LX700 with built in tuner.
3 Suggested Answers
SOURCE: Sony 60" Grand Wega has Picture go BLACK and NO SOUNDS!!!
My Sony Wega KDF-55XS955 55" was going on for 1-2 minutes then going black with no sound and after a few minutes would come back on. After reading all the posts and talking with a repair guy I replaced the bulb and that fixed the problem.
Posted on Oct 22, 2009
asnowman
  • 788 Answers
SOURCE: panasonic model pt-61hx40b screen went black now
If you turn on your set and you hear a clicking noise, or a ticking sound. You most likely have a shorted Horizontal Output Transistor (Refered to as a HOT)
I would recommend that you contact a local servicer in your area and see if they can come to your house and diagnose the problem and give you an esimate for the repair. This can be tricky to diagnose and the potential for electrical shock is very high. So I would be careful if you wish to repair it yourself.
I have done this repair before and I think that you should be able to get a servicer to your home and repair the set for somewhere between $350.00 - $450.00 depending on the parts that are needed and the area in which you live.
I hope that this helps you with this issue. If you have any further questions or, if you wish to repair it yourself please post back and I will try to help you as much as I can.
Thanks for using FixYa
asnowman
Posted on Oct 25, 2009
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
How do I fix a Samsung LED TV that has no sound and a black screen. I did verify it does have blacklights.
You have already changed every board in the TV, presume all of the board are functional, the problem would be ether the back light ASSY, or the panel itself.
Jun 30, 2017 | Samsung Televison & Video
Lcd tv has sound no picture
Hi Chad,
Since you are getting the sound, the main board seems ok. Please show a flashlight on the screen, you should be able to see the picture there. If it is so, the backlights in your set are not working. Most LED TVs have LED driver circuit on the power board now days. Here a word of caution, there are two reasons for failed backlights. First the LED driving circuit and second the backlight itself. Which one has in your case, let some TV Tech decide it. In both the conditions your TV should be repairable.
Good luck
Dec 03, 2015 | Sceptre X505BV-FMDR 50" LED TV 1920x1080,...
What is causing PZ550 Plasma TV to display a frozen image with bars, and then a black screen after restarting the TV? Sounds and TV functions work.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 08, 2015 | LG 50 50PZ550 50 3D Plasma TV
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Jun 18, 2009 | Vizio VU42L 42 in. LCD TV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Picture washed out, can't get it right
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
