Jungle controller 8 volts error
11 blink code
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 29, 2012
Sony KDF-50WE655 won't turn on.
Try to turn OFF this unit for about a day make sure its unplug from the power outlet so it will be reset, because it needs a long time to reset the TV unit....
Oct 20, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony kv 29ls35e error codes
To enter into service mode to these sets,
* Turn on the Tv with its main ON/OFF switch at its front panel. [Standby Mode].
** Press the following buttons on the remote control in sequence. [ON SCREEN DISPLAY => DIGIT-5 => VOLUME --ve => TV].
The identification of errors within the [FE-2] chasis is triggered in one of two ways. [1] Busy. [2] Device failure to respond to IIC. In the event of one of these situation arises, the software will first try to release if the bus is busy, and then communicate with each devices in turn to establish if a device is faulty. If a device is not to be found faulty, the revalent device number will be displayed, with series of flashes of LED, which must be counted. Each time the software detects an error it is stored within the NVM.
No error => 00
Reserved => 01
OCP [Over Current Protection] => 02
Not used => 03
No vertical Sync => 04
IKR Error at power ON => 05
IIC bus clock and /data lines low at power ON => 06
NVM no IIC bus acknowledge at power ON => 07
Not used => 08
Tuner no acknowledge at power ON => 09
Sound processor error => 10
Jungle controler 8V error => 11.
Jul 22, 2014 | Computers & Internet
How to find codes for check engine light on
Check Engine Light Codes and Meanings
Long blinks Short blinks Problem
1 1 Camshaft position sensor
1 2 Mass air flow sensor
1 3 Engine coolant temperature sensor
1 4 Speed sensor
1 11 EVAP control system (flow)
1 14 Fuel injection system right bank (too rich)
1 15 Fuel injection system right bank (too lean)
2 1 Ignition circuit
2 3 Closed throttle position switch
2 5 Idle speed control
2 9 Fuel Injection system left bank (too rich)
2 10 Fuel Injection system left bank (too lean)
3 1 ECU
3 2 Exhaust gas recirculation system flow problem
3 3 Front left O2 sensor
3 4 Knock sensor
3 5 Exhaust gas recirculation temperature sensor
3 6 EGRC-BPT valve
3 7 Closed loop control
3 8 Closed loop control
4 1 Air intake temperature sensor
4 2 Fuel tank temperature sensor
4 3 Throttle position sensor
4 7 Crankshaft position sensor
5 3 Front right O2 sensor
5 4 Automatic transmission control unit
6 3 Cylinder #6 misfire
6 4 Cylinder #5 misfire
6 5 Cylinder #4 misfire
6 6 Cylinder #3 misfire
6 7 Cylinder #2 misfire
6 8 Cylinder #1 misfire
7 1 Multiple cylinder misfire
7 2 Three way catalytic converter (right side)
7 3 Three way catalytic converter (left side)
7 4 Evaporative emission control system pressure sensor
7 5 Evaporative emission control system
7 7 Rear O2 sensor
8 1 Vacuum cut valve bypass valve
8 2 Crank position sensor
8 3 Absolute pressure sensor
8 4 Automatic transmission control unit
8 6 Evaporative emission canister purge control solenoid valve
8 7 Evaporative emission Canister purge control solenoid valve circuit
9 1 Front Right O2 sensor
9 3 Evaporative emission Canister vent control valve
9 5 Crankshaft position sensor
9 8 Engine coolant temperature sensor
10 1 Front left O2 sensor
10 3 Park and Neutral position switch
10 5 EGRC solenoid valve
10 8 Evaporative emission canister purge volume control valve
11 1 Inhibitor switch
11 2 Revolution sensor
11 3 Improper shifting to first gear (Automatic transmission)
11 4 Improper shifting to second gear (Automatic transmission)
11 5 Improper shifting to third gear (Automatic transmission)
11 6 Improper shifting to fourth gear (Automatic transmission)
11 7 Solenoid valve lock up function
12 1 Shift solenoid B (Automatic transmission)
12 3 Overrun clutch solenoid valve (Automatic transmission)
12 4 Torque converter clutch solenoid valve (Automatic transmission)
12 5 Line pressure solenoid valve (Automatic transmission)
12 6 Throttle position sensor (Automatic transmission)
12 7 Engine speed signal
12 8 Fluid temperature sensor
13 2 MAP/BARO Switch Solenoid Valve
13 5 Fuel pump control module
13 8 Cooling fan
Dec 12, 2011 | 1995 Nissan Maxima
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
Standby light flashes green and red, the pattern is 11 flashes, is this serious
Submit the TV to an authorised SONY workshop for a quote and a full assessment of the actual problems. This repair could prove expensive/uneconomical, but it is up to you. The quote (and their second opinion) should help.
Here is a list of the problems that might have occurred indicated by the number of blinks:
* Unit is dead, No blinks = Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
* Continuous blink once a second, no pausing = No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
* 1 blink = not used for the self-diagnosis
* 2 blinks = B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
* 3 blinks = B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
* 4 blinks = No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
* 5 blinks = AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
* 6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
* 7 blinks = High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
* 8 blinks = Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
* 9 blinks = Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
* 10 blinks = Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
I assume the TV has no picture/sound as a result.
Dec 15, 2010 | Sony KV-36FS12 36" TV
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
11 blinks onSony KV24LS35U
According to the LED error code (11 times blinking) the problem is in "Jungle controller 8 volts" which are not being produce, this kind of fault bit technically difficult to and i suggest you to contact any expert to find the cause of not producing 8 volts supply,
Hope you will understand my sayings,
Thanks for using fixya.
Jul 25, 2009 | Sony Televison & Video
Won't turn on
Although the other response is in much better technical lingo, it sounds to me like the television had a high voltage arc which I have seen on quite a few of the sony big screens lately. Usually, it causes a part on the circuit board, (one of many that were listed on prev. solver's list) to fail. This causes a delimma for the repairman, because when they find the bad part and replace it, sometimes it will pop again causing repeat failure of boards and/or parts on the board. Sony is known for having bad tubes on their projection sets, and it can be a difficult repair even for a trained tech. I suggest calling a sony service center in your area, and get an accurate estimate before deciding if replacing the set is the best idea. Hope this is helpful input, Russmann.
Nov 15, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
506 people viewed this question
Top Televison & Video Experts
Electro Med Services...
