Question about Sharp EL-2196BL Calculator
Calculation vs. print-out error
Calculates correctly, but prints completely different numbers than what's on the screen. Also, on a different calculator of the same version, I can't get the red ink to work when using doing a subtraction calc and it prints black dots all over my paper.
SOURCE: ink problem
It has a little ink roller under the plastic on the right side as you are looking at it. It is made of black plastic and pulls straight up to come out
Posted on May 13, 2008
SOURCE: Sharp EL-1801V 12 Digit 2 Color Printer
SHARP EL-1801V DON'T KNOW HOW TO SET THE DATE AND TIME
Posted on Jun 12, 2008
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
vladp995
  • 81 Answers
SOURCE: how to calculate
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
vladp995
  • 81 Answers
SOURCE: how do i perform the calculation of log (base 2)
Yes look you can't enter the base in calculators it's default 10 so use:
so instead of log 8 base 2 input log 8 / log 2 it's easy
hope you understand :)
I am using a Casio fx-9750GII, when I try drawing something, it says range error. How to fix and I need to know WHAT the numbers should be set to.
That's something we can't tell you, Paige, until you tell us exactly what calculation you're using to draw on the screen. You can't just throw numbers at it in hopes of drawing something, its purpose is to show you what a calculation looks like graphically so you can better visualize your results or predict the results of a subsequent calculation. It's not built to be a toy, it's built to be a working tool.
Aug 07, 2014 | Casio Office Equipment & Supplies
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
Simple math - $200.00 times 22 LCD shows correct $4400.00 Print out shows - $100.00 times 22 equals $4300.00
Sounds like you could have $100.00 in your memory. The LCD will show your current calculation but the print out might include anything you added to M+/-. Try clearing your M*
Jun 17, 2010 | Victor 2640 Calculator
CALCULATOR MIS-FUNCTION .
unfortunately the printer is out of time or the selector pawls got bent. would be cheaper to buy a new one than fix this.
Apr 28, 2010 | Sharp EL-1197PIII Calculator
Settings
I bet your display is showing the correct ans, however your printer is printing incorrectly. Settings have nothing to do with your ans. You need your printer to be cleaned or have the printer replaced with a rebuilt unit. I can do this... 608-222-2484...
Oct 22, 2009 | Monroe 7130 Calculator
THE CASIO HR-100TM HAS AN E ON THE SCREEN AND THEREFORE I CANNOT USE TH MACHINE. HOW DO I REMOVE THE E
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
http://www.casio.com/support/techsupport/AABF4C3A-D2EF-4BF5-B349-48459AF35FF0
Jun 24, 2009 | Casio HR-100TMPlus Calculator
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
Ma error appears in stat menu with casio cfx-9850gb plus
Here are the possible causes for such an error
1. calculation results exceeds calculation range.
2. Calculation is outside the input range of a function
3. Illogical operation (division by zero, etc.
4. Poor precision in sigma calculation results,
For all these reasons
Check the input numeric values and correct them . If you are using memory, check that the numeric values stored in memory are correct.
Hope it helps
Apr 07, 2009 | Casio CFX-9850G Plus Calculator
Printing error
the problem is with the printer. try to examine if the printer head is on the right side. the default must be on the right side. if you can't move the printer head towards the right it means it got stuck up. if you will look inside it you will see a 'rail like' object on the bottom of the printer you can push it down with any pointed object for the pinter head to get back to its original position. if this doesn't solve the problem look for the nearest service center coz the printer needs an alignment.
Aug 10, 2008 | Casio HR-8TMPlus Calculator
How do you do basic subtraction?
Equals is used during a calculation of division, percentage, multiplication, etc. Use the total key or * key for a total of substraction or addition.
If this helps, please rate me. Thanks, Patty
Dec 28, 2007 | Canon P23-DH Calculator
Sharp EL-2196BL Calculator Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
