Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Proform pro 4500 freezes
Speed or incline can't be changed and the screen (track) does not advance
    Top Expert:
  • Proform Master
  • 12,223 Answers
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) Replace the new batteries, with the same type, same marks, and the same polatity
3) clean the contacts batteries spring, with c. cleaner from some electronic store.
4) Tigtht the ribbon cable inside from control keypads.
5) Try to RUN the software calibratin for easy diagnose, troubleshooting and fix it.
God bless you
Posted on Nov 29, 2012
  • 3 Answers
SOURCE: Treadmill will not maintain the correct speed.
your belt may not be tight enough and it is slipping which can cause it to move faster than the motor
Posted on Aug 26, 2009
maxtreadmill
  • 832 Answers
SOURCE: i have a proform 785..the problem is the speed and
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
Press either incline key and the incline will calibrate automatically
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
Press the Stop key once and remove the safety key.
Posted on Jun 14, 2010
ercupa190
  • 12223 Answers
SOURCE: only one program works. you
Dear Sir:
I will help you inmediately.
SOLUTION: a. Remove the key from the console and unplug the
power cord. Remove the screws from the hood and
carefully remove the hood. Locate the Reed Switch
and the Magnet on the left side of the Pulley
. Turn the Pulley until the Magnet is aligned with
the Reed Switch. Make sure that the gap between
the Magnet and the Reed Switch is about 1/8ó. If
necessary, loosen the Reed Switch Screw and
move the Reed Switch slightly. Retighten the Screw.
Re-attach the hood, and run the treadmill for a few
minutes to check for a correct speed reading.
Please check it and contact me if there are any additional help. blessing. sincerely.
E.Cuadra
Managua, Nicaragua
Posted on Sep 14, 2011
ercupa190
  • 12223 Answers
SOURCE: my proform incline won't recline
Dear Sir:
I will try to help you.
Please see the video with patience and carefully. you nee basic tools+Dvom
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
DC to +12vdc) then the +12V LED lights.
This the board LED, who control the signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
With this you will fix it.
If you need further assistance, please reach me, sincerely.God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Posted on Oct 26, 2011
ercupa190
  • 12223 Answers
SOURCE: proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Posted on May 17, 2012
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
Apr 03, 2013 | Startrac Fitness Products Star Trac 4500...
Hello i have a proform crosswalk sport treadmill and when i turn the speed on it shows a reading for a couple of seconds, but doesn't come on. The incline works just fine. The motor will turn manu
adjust the REED switch see the diagram attached m clean it+test for open or faulty with DVOM, tight the connector very well,However try to RUN the software calibration and fix it. see the diagram attache too for speed sensor, adjust it and test it , clean it, and tight very well the connector.God bless you3_22_2013_4_18_58_pm.gif3_22_2013_4_19_19_pm.gif3_22_2013_4_19_33_pm.gif
Mar 22, 2013 | ProForm CrossWalk Sport Treadmill
Why does my Nordic Track Reflex 4500 Pro incline automatically when I start it up?
You must tried again the s.calibration, for easy diagnose, and troubleshooting.
However you must Adjust the speed sensor, test it, clean it, and tight any plug or connector, see the diagrams attached and proceed according.
2) Lube the elevation motor, the shaft + gear, test the motor itself for open or short. see the diagram attached. If you machine use RELAIS test it for dirty, or open and repair.
God bless you
Nov 27, 2012 | Nordic Track NordicTrack Reflex 4500 Pro...
My TM won't work in the incline mode. We recently reset it up and started it before we had it in the proper alignment (walking surface to motor) and engaged the incline function. There was a bolt
Please RUN the software caibration for diagnose, troubleshooitng, and fix it Maybe you have speed sensor faulty or bad adjustment, clean it and tight wires connector.
God bless you
Jul 26, 2012 | Proform Quick Burn Pro Treadmill with 12...
Treadmill makes a noise then shoots the speed very fast all of a sudden
Dear Sir:
Hello , I will try to help you.
Please see the next videos:
And carefully:
http://www.youtube.com/watch?v=yX_0vRPdMfU&NR=1
http://www.youtube.com/watch?v=N6Yg5S0WML8&NR=1
http://www.youtube.com/watch?v=E5aWisfhT3Q&feature=related
If after that you need further assistance, please reach me. sincerely. God bless you.
E.CUADRA
Oct 12, 2011 | Proform Treadmill Incline Motor Sears Pro...
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
125 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
