Question about CTL 24 LP2361 LED Computer Monitor
CTL LP2361 drivers - CTL 24 LP2361 LED Computer Monitor
HOW DO I ROTATE MY SCREEN USING SHORT-CUT KEYS
Depending on your driver, it can be ALT + left arrow (or right arrow), or CTL + left arrow (or right arrow), or MAJ + left arrow (or right arrow), or any combination of ALT, MAJ, CTL plus one of the direction arrow...
Nov 08, 2014 | Microsoft Windows XP Home Edition
Medion How To
Basically it is drag and drop. Plug your USB external drive in. Navigate to the drive and folder you wish to store them and minimise the page. Go to Picasa and right mouse click on the photos you want then when what you require are highlighted press Ctl and C together. Maximise your external drive, select where you wish them to go and press Ctl and V.
Ctl and C = Copy
Ctl and V = Verify or Paste.
Hope that helps.
Oct 28, 2013 | Computers & Internet
Cant find my drivers anywhere
Kind of an off-the-wall computer. Here are some links that may help, not sure where you were looking before. Who makes this thing?
http://ocram.org/wiki/Computer_Specifications/Advent/7110
Not the same model, but based off of the 7110 so some drivers may work:
https://ctl.box.com/shared/mlqvvza3ar/%5Bobject%20Object%5D/66840785
This site is mostly just information, but you can individual manufacturer driver repositories with the model numbers provided:
http://www.uktsupport.co.uk/advent/laptop/7110.htm
Jul 06, 2012 | Computers & Internet
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
Blue notebook model il1 drivers
just download cobra universal driver to install drivers of your laptop or download 3dp chips to detect drivers need of your latop
Oct 08, 2011 | CTL IL1 Notebook
No webcam driver for ctl il1 laptop for windows xp
this what you are looking for>>>http://www.4shared.com/file/Wp_-VzZx/SkyDriver_XP_99.htm
Oct 23, 2010 | CTL IL1 Notebook
Helo can u help me, i lost my driver disk for my CTL IL1 7" Laptop Black PC Notebook.
if you go to the manufactures web site, i am sure you will be able to download the device drivers
Mar 19, 2009 | CTL IL1 Notebook
Sony K60XBR800
Model
KF50XBR800, KF60DX100, KF60XBR800
RESOLUTION
Yes. Try the attached procedure. This has proven to be very effective.
Enter the service mode by pressing Display, 5, Vol +, Power.
Press Menu and go to Setup. Select Image Revision and set to 1. Press Menu once to exit the menu screen.
Cycle thru the service mode using button 5 until you get to D-GM TG. Press number 1 on remote once. You should now be at the 1 POS CTL. Change data from 11->1.
Push the number 1 button on the remote 14 times until you are at 15 ENB POS. Change data from 5->23.
Push number 1 button on the remote 8 times until you are on item number 23 PRG POS. Change data from 0->2. Write the data to memory by pressing MUTE, ENTER.
Push number 2 on remote 6 times until you are at H POS SHIFT. Proceed with the following steps very carefully. 0 VAR POS-CTL=0. Press number 1 on remote. Change D-GM HP item 1 from 9->11. Write the data to memory by pressing MUTE, ENTER.
Press 4 on remote. Change to 0 VAR POS-CTL=1. Then press #1 on remote. D-GM HP ITEM #1. Change data from 9->11. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=2. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=3. Then press #1 on remote. D-GM HP ITEM #1. Change data from 8->10. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=4. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=5. Then press #1 on remote. D-GM HP ITEM #1. Change data from 7->9. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=6. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=7. Then press #1 on remote. D-GM HP ITEM #1. Change data from 6->8. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=8. Then press #1 on remote. D-GM HP ITEM #1. Change data from 5->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=9. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=10. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=11. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->6. Write data.
Press 4 on remote. Change to 0 VAR POS-CTL=12. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=13. Then press #1 on remote. D-GM HP ITEM #1. Change data from 11->7. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=14. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data. Press 4 on remote. Change to 0 VAR POS-CTL=15. Then press #1 on remote. D-GM HP ITEM #1. Change data from 10->6. Write data.
Press #5 on remote 6 times back to catagory D-GM TG INV CTL. Press number 1 on remote once to the Catagory D-GM TG 1 POS CTL. Change the data value to find the best setting where no double images, ghosts nor merged colors appears. WRITE DATA.
Press #2 on the remote 11 times to the Option-E O Lamp Time. Note the current value and write it down. Add 2000 to the value (ex if 1356, than 1356+2000= 3356). Divide this number by 100 and write this value to the Option-E 11 P CTL SHT1. For our example above we would have 3356/100= 33.56. So we can round to 34.
Now add 50 to this number. In our example we would have 34+50=84. Write this value to the Option-E 12 P CTL SHT2. Make sure to write the data.
Select AUTO in the menu for the Image Revision setting and exit the menu screen. Confirm that the picture is fine.
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
CTL 24 LP2361 LED Computer Monitor Logo
94 people viewed this question
Top CTL Computers & Internet Experts
Marcin
Joseph Hoffmann
JonSnell Electronic
JonSnell Electronic
Are you a CTL Computer and Internet Expert? Answer questions, earn points and help others
