Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
Clean roller manually lexmark prospect pro205
Printer will not feed paper from paper tray
2 Suggested Answers
SOURCE: Paper will not feed into
hi,
Lets clean it this way;
- open any documents - go to file > print ( or ctrl + P) - When the print window opens click 'properties' - In the properties window click 'Maintenance' - 1st do the normal 'cleaning' - 2nd do the 'deep cleaning' - do the print Head Alignment' - do Nozzle check' - Skip 'Ink cartridge settings' (if the ink level is ok) - do 'Bottom plate cleaning' - do 'Roller cleaning' - click 'OK' - turn Off and ON printer.
Now insert the load paper and take print. : ) done Hope this helps.
Please rate if this solution was helpful, thanks!
Posted on Jul 13, 2011
Will I be able to make a legal size copy on my Lexmark Prospect 205?
The printer takes A4, Legal and letter size paper.
see the specifications at this site.
Sep 15, 2014 | Lexmark Prospect Pro205 Wireless...
Why does lexmark prospect pro 205 says paper jam when there is no paper jam
may be there is problem with paper path sensor faulty or maybe broken or may be the problem with power of the paper path sensor there should be 5v dc present on sensor
Jul 14, 2014 | Lexmark Prospect Pro205 Wireless...
How do I clean the print head on the lexmark pro205?
The manual explains. It can be downloaded from... http://www.manualslib.com/manual/291570/Lexmark-Prospect-Pro205.html
Jun 30, 2014 | Lexmark Prospect Pro205 All-in-one Inkjet...
My Lexmark PRO205 seems to have eaten a staple. How do I disassemble it enough to get at the paper feed mechanism?
If you're fit enough to turn the printer upside down, try to do that and shake the printer with the scanner cover open.
Aug 09, 2012 | Lexmark Prospect Pro205 Wireless...
How to replace lexmark pro 205 belt
If your printer is still under warranty, contact our technical support team to have the printer replaced. You can find our contact details at www.lexmark.com.
Apr 13, 2012 | Lexmark Prospect Pro205 Wireless...
Lexmark prospect - can i print in black and white only when my colour cartridges are empty
The Lexmark Prospect Pro205 requires all the cartridges to have ink in them to continue printing even if your printing in "black and white" only.
Aug 29, 2011 | Lexmark Prospect Pro205 Wireless...
Had paper stuck in feed . reached in, got it out. Now printer will not print because it says ' out of paper' when there is paper in it.
Hi, Pul the plug for 30 minutes and try agian. By pulling the plug you reset the printer. Next, make sure your paper is in correctly. If it is in incorrectly the feeder will jam. Do not go beyond the feed mark on tray. Good luck.
Jun 18, 2011 | Lexmark Prospect Pro205 Wireless...
Our Lexmark Prospect Pro205 has sufficient ink in the black cartridge. The error message says there is interference with the black ink cartridge. Black ink does not print, but color inks print.
Your cartridge may need to cleaned. On the printer operator panel, press Setup button -> Maintenance -> Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, your printer probably needs to be updated. The firmware update, available at http://bit.ly/p205fw, will help fix print quality issues.
May 02, 2011 | Lexmark Prospect Pro205 Wireless...
We brought a Lexmark Pro205 and it comes up with a paper jam when we hadn't put any paper in, we had literly taken it out of the box, how do we solve this???
ligned sponge located below the printhead. Should you have a paper jam and want to pull out the paper from inside the printer, there is a possibility that you will also pull out some parts of the sponge. The improperly placed sponge may then cause the paper to jam again.
Solution
If you realize that the sponge is not in its proper position, you will need to push it to the correct position (as seen on the images below). Then, when paper goes through the rollers, it will not be blocked by the sponge.
Properly placed sponge (Click for larger a view.) Improperly placed sponge (Click for a larger view.) jam_1.png jam_2.png
Oct 28, 2010 | Lexmark Prospect Pro205 Wireless...
Lexmark c720 color laser printer
please chack it feed claught unite
thanks
Jul 30, 2009 | Lexmark C720 Laser Printer
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
64 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
