Question about Hotpoint 24 in. DWF33 Built-in Dishwasher
Hotpoint Aquarius DWF33 5 years old just makes a grumbling noise
But will not start the washing cycle same result on any program water inlet and outlet both look ok
    Genius:
  • 1,550 Answers
Reset dishwasher
Make sure dishwasher is empty of water.
Turn off Dishwasher
Turn back on and within first 3 seconds press black button 4 times
Push door closed and let washer go through cycle
Posted on Jan 10, 2009
Not enough water for wash
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 21, 2013 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius will not spin
If the inlet cycle proceeds and then activated the wash after the water level is detected then the program cycle is intact. However if the second spin does not start, you need to check if there is voltage to the motor at this time , if not the control panel memory to the processor can be corrupt or the IC damaged.
Jul 03, 2012 | Hotpoint WML520 Washing Machine
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
Drum makes loud noise as rotates clockwise
put few clothes in it drum to switch on its ball in there
Oct 06, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Leaks after wash programme ends
Check your inlet hose or hoses if it is hot and cold fill.
Turn off supply to washer and see if it still leaks, if it does then you have water coming from inside m/c somewhere
Nov 23, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Motor running drum not emptying
sounds like maybe a blocked pump.Probably got a coin or sock or some lint in the pump.Has your machine got a filter ? What happens when you position the program switch on a spin section and turn it on ? does it pump out the water ?
Sep 14, 2008 | Hotpoint WMA64 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Hotpoint 24 in. DWF33 Built-in Dishwasher Logo
304 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
