Question about Acer Aspire 7741Z-5731
My mouse pad doesent work
When i touch the tract pad the cursor dosen't respond until i press function 9 or 10
  • Acer Master
  • 27,725 Answers
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys.
If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box. Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter."
Your touchpad will be re-enabled.
hope this helps
Posted on Nov 29, 2012
Compaq cq60 311-sa touchpad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 09, 2012 | Computers & Internet
Touch pad not working
Did it work for you before? what has happened since then?some laptops have a way to disable the touch pad so you won't accidentally move the cursor while typing. It may be a switch on the computer itself, or a LED in the corner of the touch pad, or it may be one of the Function keys (does any of them have a symbol of a mouse with a circle and one diagonal line indicating "no mouse") If so, push the fn key plus which ever function key has that symbol beside it.Some laptops automatically disable the touch pad if a USB mouse is plugged in.If none of these is the problem, you may not have a touch pad driver installed. Get a USB mouse to plus in until you get the driver installed. Go to the web page for the manufacturer for the laptop. Search for your model in the support section, and look for drivers. Download the appropriate driver for your touch pad and your version of Windows, and install it.Buying a USB mouse or a wireless mouse may be a valid solution no matter what the problem is if you like a real mouse.
Mar 02, 2012 | Computers & Internet
Cursor doesn't move
connect a USB mouse and try if it's not work replace touch pad
Jan 10, 2012 | Acer Aspire 5570-2067 Notebook
I cannot move the arrow
Perhaps your mouse is not plugged in to the computer. If your mouse is a usb mouse it will have an end of it that looks like this:
http://cache.gawkerassets.com/assets/images/4/2008/11/usb3.jpg
It probably isn't blue on the inside though. It's probably silver or black
If your mouse is a ps2 mouse then it will look like this:
http://www.york.ac.uk/admin/sro/Photos/PS2connection2.JPG
If the mouse is a ps2 mouse then when you plug it back in you will need to log off and then log back on to your computer for it to work. To log off you can press the windows key that looks like this:
http://daily-grind.net/wp-content/uploads/2010/08/Windows-Key-722215.jpg
and then use the tab button to navigate to the log off button and hit enter. Then hit tab until you can select yes and hit enter.
If it is a usb mouse then you can just plug it back in and it will work.
May 09, 2011 | Computers & Internet
I have a medion akoya E1222, and when you type the cursor will move to a different part of the text.. muddling up the words...Very annoying
That is because your thumb is touching the cursor pad. It happens to everyone who uses laptops. Some laptop designers put the cursor pad off-centre because of this. With the akoya e1222 you can press [fn]+[f9] and that will disable the cursor pad. That way if you touch the pad by accident you don't mess up your words. When you need to use the mouse again press [fn]+[f9] again to re-enable the cursor pad.
With any laptop it pays to play with those function buttons. There are always some useful ones there.
-Makoto
Jan 14, 2011 | Computers & Internet
Mouse pad not moving the cursor
There will be a Fn combination for the mouse pad.Please have a look on the fn (F1 to F12) keys on top of the keyboard and you will find the mouse pad symble on any one.
Press that function key with fn key (usually with windows button) and the touch pad will start working.
Thanks.
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
My laptop computer is okey except that the touch command for the cursor is not responding, if i use a mouse thru the usb port then its alright..why does the touch command for the cursor not responding?
Touch pads are not very reliable. I have seen a lot fail.
A computer repair person will need to replace it for you.
My advice is to stick with a USB mouse. Or if it is under warranty, take advantage of that warranty.
Best of luck.
Apr 26, 2009 | Acer Computers & Internet
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Open Questions:
See all Acer Aspire 7741Z-5731 Questions
Acer Aspire 7741Z-5731 Logo
255 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
