Question about GE HO97685 Remote Control
Remote the remote is not working with any of my devices. followed al the steps.
  • 56 Answers
This is from your producer: Product Description ? BASIC OPERATION OK ? everyone knows what a handheld remote control unit does for your home electronics. You can control your basic four (4) components: TV, DVD player, VHS player, Cable or Satellite tuner. Setup is simple for these basic 4? put in the batteries, look up the manufacturer of your component (Mitsubishi TV) and note the possible 3-digit ?program codes?? turn on the component, press the remote control?s PROGRAM button until the light stays red, press the component button (i.e., TV), enter in the ?program code?, and press the ?power off button? ? if the component (i.e., TV) turns off: you are programmed! If the component (i.e., TV) doesn?t turn off, then repeat the sequence using another of the manufacturer?s program codes until it does. Easy ? took me about 3 minutes to program my old Zenith TV (in the bedroom), my SONY DVD player, and my Mitsubishi S-VHS player. No problems at all. HOWEVER, in case you do run into a component for which the ?program codes? don?t work? you can go through a sequence to self-identify the coding. While I won?t go into it here, it is only slightly more time consuming than the other method. As my codes worked fine, I can not address this aspect, so I won?t make a claim we didn?t test.
Posted on Jul 31, 2007
  • ali sahib
    ali sahib Jul 31, 2007
    please rate me if you find this is a helpful comment
Hey there, I've tried programming my large BrookStone television remote with many different online methods, but none of the different solutions are helpful to my TV remote. Do you have any advice?
If the codes do not work then the only other option is to do the following steps to PowerScan through the remotes codes to see which one will work. If none work then the remote does not accept your tv.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds,
Feb 08, 2011 | Brookstone 538744 Remote Control
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
TRYING TO PROGRAM REMOTE IT IS A RCA REMOTE LOST INSTRUCTIONS TO REMOTE.
HI, Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
4. Release "CODE SEARCH".
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
follow the below steps to set remote without codes
Code Search: 1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote 2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Nov 08, 2010 | RCA Universal Remote Control
I have an old RCA TV (about 20 years old). I got the TV from a friend and she could not find the remote. I bought this remote but I cannot find the correct code to get it to work. Are there other codes...
HI,
Direct Code Entry:
Code Search:
Thank you
Sep 13, 2010 | RCA RCU410MS Remote Control
I have and old floor modal tv in good condition I have a Rca universal remote that I dont have the program codes and cant seem to fine them online
As we dont know the TV make you can use code search method.
It basically searchs the codes automatically.
Code Search:
If you can find the codes for your /tv please follow the below steps
Direct Code Entry:
Thank you
Aug 07, 2010 | RCA 6-Device Universal Remote
When I try to download music from pc to my ipod, pc says connect
Hmmmm check wit the data cable once.. try using different USB ports els different data cables itself..
- if cable workin fine den try doin a hard reset.. i.e with d iPod plugged in 2 d comp try resetting iPod..
-Els check if ya iPodz getting recognized in iTunes.. if itz gettin not gettin recognized reinstall the itunes software.. or follow dese steps-
1>www.apple.com
2>Click on the tab SUPPORT
3>Select iPod+iTunes
4>Select iPod nano 4 r 5th gen
5>U'l find many divisions as get started troubleshooting n al.. under troubleshooting d 3rd link i.e iPOD DOESNT APPEAR IN ITUNES n follow d steps
-if itz gettin recognized in iTunes n not gettin recognized in comp den follow d same steps til troubleshooting.. under dis go to d 4th link i.e iPod is not recognized properly by computer when USB drivers are not installed properly r out f date..
Try wit al dese steps.. hope sumthin works out 4 u..
If none f dese work den derz another step to it.. may b disk mode step which am not sure f.. try finding out regardin diskmode n may b dat'l help ya..
May 26, 2010 | Apple iPod nano
Need the code to set the technika remote to ma toshiba telly
Maybe you could try the auto-set. Found this using google:
Auto code search
1. switch on the TV and select a channel eg. Bbc1 on the TV itself
2. press the appropriate device button eg. TV
3. press the green SET button for approx 5 seconds until the red light comes on.
4. release the green SET button and point the remote at the device to be controlled, the remote will emit a test signal about every 2 seconds.
5. when the TV switches itself off briefly press the green SET button to store the code found.
6. when the red light goes out the search is ended.
7. try out the remote if it works follow the same steps to set it to other devices eg. DVD. If it does not work follow the steps again.
cover other remote sensors on other devices when setting the remote.
Apr 01, 2010 | Televison & Video
Technika tt-16 universal remote control codes for a beko tv
Auto code search
Nov 10, 2008 | RCA Universal Remote Control
REMOTE DONT WORK WITH MY TV
hi go here for the complete usermanual, and try thid following.
If none of the codes listed under
“Device Codes”on the back of this
guide match your device, you can
search for a set of commands that will
work. Your remote will sample all the
codes in its system for that device
mode to find one that will allow you to
control your device.
1. Press and hold a device mode
key (AUDIO, DVD/VCR, or TV) for
at least six seconds. The LED for
each device key lights up, then
the key for the device you
selected remains on.
2. Press a function key (such as
Power or Mute). The following
function keys are valid for
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
The device key’s LED blinks
three times, then turns off.
3. Press !. The remote will send
the IR command for the function
you pressed in Step 2.
4. If the device performed the
function you pressed, press OK.
The remote will now control the
device you selected in Step 1.
If the device did not perform the
function you pressed, repeat step
3. Press " to retry the previous code
I hope this helps
Please rate accordingly
Thank You
sserpentio
Mar 28, 2008 | Motorola Mobility DRC800 Universal Remote...
Remote dont work with my tv
Searching (Power is
recommended):
• Power
• Mute
• Play
• CH +
• Stop
I hope this helps
Thank You
sserpentio
GE HO97685 Remote Control Logo
247 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
