Question about Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard
Gigabyte 7NF-RZ board is fried. Replace it with? Same board or is there a better way to go
I have to replace it but am thinking if there is a better board that will work for around the same price. I am new to computer building and am just learning how it all works. Thank you for your time
  • 2,878 Answers
Take same hardware like CPU and RAM in to consideration. Make sure these are compatible. This is where a whole new system takes root.
Posted on Nov 28, 2012
I want to know the specifications of the Gigabyte 7NF-RZ:- 1.The max support of the DDR ram 1 or 2 and to 1or 2 GB? what HZ should be used? Regards, Edwin s.
Hi, the mainboards homepage is here:
http://ee.gigabyte.com/products/page/mb/7nf-rz/
Your mainboard supports:
DDR 1, 333 / 266 mhz 184pin 3 x DIMM slots up to 3GB
The mhz is not so important
it can easy run with 400 mhz
if the cpu supports it.
Sep 14, 2011 | Gigabyte Computers & Internet
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Hi all, i m having- G 81845GVM-rz mother board can anyone please give me all driver, i m not able to find it on google and also gigabyte site plz help urgent......?
Perhaps it's because you think the i in GA-8I845GVM-RZ is a One. (1)
GA- 8 - 'eye' - 845GVM-RZ
(Capital I)
Gigabyte Support > GA-8I845GVM-RZ main support page,
http://www.gigabyte.com/search/search.aspx?kw=GA-8I845GVM-775+%28rev.+1.0%29
Click on the Downloads (1) tab.
Now click on the Driver tab.
To the right of the - Choose Your OS - box, click on the blue down arrow.
Now click on the Operating System you are using.
Audio - RealTek AC '97
To the far right click on the country nearest yours.
Regards,
joecoolvette
Jul 16, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Hi i have a motherboard gigabyte 7nf-rz this motherboard dont have an integrated vga so i have to use a video card, i have an nvidia 6200 agp video card conected the vieo card to it an theres no video on...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need or major geeks download this graphics driver this will depend on your operating system
http://download.cnet.com/%7Bvalue=http://www.download.com/ati-catalyst-display-driver/3000-2108_4-10608736.html
This is a WHQL release from the Release 260 family of drivers. This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. What
Apr 19, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
7NF-RZ Motherboard not go on
Is the cpu ok? Without the fans the life of the cpuis very little.
Stelios.
Feb 22, 2010 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Ddr ram
welcome to fixya
if something burnt out most of the time the mother board is gone (junk) if nothing eles try to remove the new memory and try to reboot if still nothing happens then you fried the motherboard
sorrry to hear this
have a good day other wise :)
Jul 31, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I need to find a motherboard diagram for a EP-8KDA3J motherboard
for what model? and i don't think you will be too likely to find wiring diagrams for mb's. i would suggest searching on google.
May 20, 2008 | Computers & Internet
Gigabyte 7VT600P-RZ (GA7VT600PRZ) Motherboard Logo
55 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
