Question about Stihl 031av Manifold /intake Boot 032 030 031 Av 1113-141-2201 Jf
My stihl 031AV chainsaw bogs down when pulling trottle
New rings,new spark plug and points are gapped at .016
  • Bob Martin Dec 07, 2012
    I put another carburetor on the saw and it does the same thing, it will start up and run but when I give it gas it bogs down.It idles but has a kick or jolt in it when idling.Also the fuel line to the gas tank seems checked out okay.
  • Bob Martin Jan 20, 2013
    I put an electronic chip in it and removed the points. It would then rev up but not idle. then I blocked carb inlet and muffler inlet and put air test through spark plug opening. I had an air leak at oil seal on clutch side. I replaced oil seal and now the saw runs perfect.
  • Stihl Master
  • 1,807 Answers
Ive had numerous similar faults with both stihl and husqvarna saws. all turned out to be leaking fuel tank vents. Im not sure if this model has a vented tank or not but it might be worth checking. Sounds like a fuel/air issue.
Posted on Jan 19, 2013
3 Suggested Answers
SOURCE: have stihl O25 chainsaw, starts, runs about 5
hey have the same o25 stihl,great saw when their working right.have had to replace fuel line to carb 5x over 7yrs.hairline crrack and it will **** air and conk out in 2-5 seconds.also there is a pulse line to carb which can also crack.if you have good spark at plug its likely a fuel delivery problem. collin
Posted on Jan 15, 2011
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
Why Do I Not Have Any Spark From The Ignition Module When Spark Plug is in The Cylinder
Search Results
    Stihl TS400 / TS420 Ignition Module Repair - YouTube
    ? 7:06
    https://www.youtube.com/watch?v=AvPv88SELXs
    May 1, 2011 - Uploaded by donyboy73
    Learn HOW TO REPLACE The Ignition Module in your StihlTS400 / TS420 ... I have a homelite 33cc Ranger it has no sparkat the plug but if I put a ... a good spark and there is fuel getting into the cylinder head also what are ...
    All comments on Stihl TS400 / TS420 Ignition Module Repair
    https://www.youtube.com/all_comments?v=AvPv88SELXs&lc...
    Donyboy73, I hava a Stihl TS 420 and just replaced the pull rope (not sure what's ... a good spark and there is fuel getting into the cylinder head also what are your ..... Hi mate, i have no spark to my plug?? i have tried a brand new plug and still ...
    Small Engine Ignition: Ignition Wires, Chainsaw Spark Plugs ...
    www.hlsproparts.com/small-engine-ignition-parts-s/149.htm
    66 results - HL Supply has the small engine ignition parts that will get your ... parts right here: ignition wires, chainsaw spark plugs, ignition coil sets, ... Please don't hesitate to contact us if you have any questions. ... Stihl TS400 (3-bolt old style), TS460 ignition coil with wire and cap ... Fits: Stihl TS410 and TS420 cut off saws
Feb 08, 2016 | Stihl TS420
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
How to replace a oiler on a stihl chainsaw ?
Remove the worm, sealing ring and washer, loosen the pan head screws on the oil pump and replace. Check if the gasket is re-usable.
Jun 11, 2014 | Stihl Service Manual for 031AV Chainsaw...
Air gap and spark plug gap 025stihl chain saw
the air gap is about a business card thick and the plug gap is .020. Stihl has a special tool to measure exact air gaps so the business card is close
Mar 20, 2013 | Stihl Garden
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
My stihl 441 chainsaw runs but wont rev. at full throttle it bogs down.
clean the carburetor, replace the air filter and check the spark plug gap. .
Apr 18, 2011 | Garden
Weak spark hard start stihl 021
Check the pole gap on the ignition module to the flywheel magnets. Use a thin business card for a gauge. If it has the correct gap and you have tried a new spark plug, then the module itself is likely failing. Hope this helps!
Apr 14, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Chainsaw will not run once you take the choke off.... runs good with choke on. walbro wa2c for stihl 031av chainsaw
Most likely the fuel filter in the tank is plugged you can get it out with a pair of needle nose pliers and buy at any saw shop. Hope this helps.
Jan 19, 2010 | Garden
Stihl 031av Manifold /intake Boot 032 030 031 Av 1113-141-2201 Jf Logo
563 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
